#1
Posted 05 February 2025 - 11:13 PM
#2
Posted 06 February 2025 - 01:25 AM
It may not be the gears, it may be the bearings. Sometimes the bearings can have the grease dry up especially if the mount has been used a lot. you might want to try giving your mount a check to see if the bearings need to be serviced and regreased. See here:
https://www.youtube....h?v=rsr7m1ejjVU
You might also need to adjust the backlash somewhat after you do this. see these two videos:
Part 1:
https://www.youtube....h?v=kohGi4uiC5c
Part 2:
https://www.youtube....h?v=Hg3OK2oBTbs
Edited by bignerdguy, 06 February 2025 - 01:25 AM.
#3
Posted 06 February 2025 - 04:55 AM
The OP has changed and greased the bearings !
When the clutches are released the worm is no longer connected.
So any binding may be due to preload, or misalignment of the bearings.
#4
Posted 06 February 2025 - 05:16 AM
Also tagged with one or more of these keywords: Mount
Equipment Discussions →
ATM, Optics and DIY Forum →
1990's Meade 10" Starfinder: Simple DIY Upgrades (& Questions)Started by dr_gn , Yesterday, 06:04 PM ![]() |
Equipment (No astrophotography) →
Putting a Synta EQ1 to Good UseStarted by dmgriff , Yesterday, 05:18 PM ![]() |
Telescope Specific Forums →
Meade Computerized Telescopes →
ETX-90 Tube Rings Source FoundStarted by tg_quigley , Yesterday, 02:13 PM ![]() |
Mounts →
OG Star Tracker V2Started by Rince , 13 Mar 2025 ![]() |
Mounts →
Help setting meridian flip on NINA with Losmandy G11Started by francomeconi , 12 Mar 2025 ![]() |
