Good day Cloudynighters.
I enjoy wide views as much as anyone - probably a bit more than most.
However this eyepiece is not one I reach for at very low powers and I am not sure why.
Whether using my 80 F6 triplet, or my 102/F5 I tend to ignore this eyepiece. I prefer instead to use a 30mm UFF or even a five element 38mm 70 degrees with soft edges. This is despite the 24mm 82 being well corrected to the edge.
However in my 120 F8.3 I really like using the 24mm 82 degrees.
In the shorter scopes the 24mm 82 ( I'm actually sure Celestron got it right with the Axiom and it's 23mm) gives around 4 degrees. This extra wide views seems to put some kind of pressure on the eyepiece and I feel the view is a bit unnaturally distorted.
Is distortion in a 82 degree EP more obvious with decreased magnification/wider FOV?
I have other shorter focal length 82 degrees EPs and I don't have any issue with them, although they provide higher magnifications.
Foot note. I believe the ES fieldstop is accurate. However I think the EP is approximately 23mm 84 degrees and not 24mm 82 degrees.
