What are the best commercial power supplies available (in your opinion) for the Rainbow Astro mounts? I'm not a homebrew kind of guy....
If you are not the homebrewing type, just use your 12V supply, but with very short cables, or very heavy (14 AWG like) cables. Guiding will not be nearly as precise as a 15V to 16V supply, but should work well enough if you don't want to put in the extra effort.
(The recommendation for using a 15V-16V supply came from Xuranus on this forum some time back. Xuranus [Byongyun Jeong] is an R&D manager at RainbowAstro and RainbowRobotics.)
If you are looking for a brick style switching power supply, in general I recommend using the "medical" type supplies, they have better noise specs than cheaper ones, and they have much better isolation from the mains, for safety (as required by the medical profession). Like this 15V one,
https://www.amazon.c...l/dp/B08YZ214C2
Just look for a "medical" supply that is capable of more than 3A. Mouser Electronics also sells the Mean Well medical power supplies, and have a more complete selection than Amazon.
https://www.mouser.c...an-well-medical
If you use separate power supply for the mount and the rest of your equipment, make sure that you connect the ground return of the 15V supply to the ground return of the of your regular 12V supply near to your mount, using a heavy ground strap, to prevent large currents through the fragile ground return of your USB ports. Do this even if you are not a homebrewing type.
That being said, any power supply needs to be close to the mount, otherwise there is too much voltage drop on the 15V cable unless you use heavy cables. Even a pair of 18 AWG copper cable that is just 10 meter long (thus 20 meter feet total when you include the ground return) has 0.4 ohms, and will cause over 1V drop at the peak 3A when the mount is slewing. This is why good larger supplies have 4 wires, two of which are sense wires, to make sure the far end of the cable is at the target voltage. An example for a 15V supply is this:
https://www.amazon.c...l/dp/B08XQT35PF
A single 18 AWG copper cable has a resistance of 21 milliohms per meter. A 16 AWG cable has 13 mΩ/m, and even a 14 AWG cable has 8 mΩ/m.
This is why it is better to simply install a 12V to 15V boost (or buck/boost) switching converter near to the mount, with a short cable from it to the mount. And don't forget a ground strap between its ground return and your 12V ground return. You can find many boost converters at Amazon, like this one:
https://www.amazon.c...r/dp/B08JG4FJ7N
Chen
Edited by w7ay, 14 February 2025 - 03:19 PM.
