I have a bit of a dilemma. With the full moon firmly ensconced in the middle of the month we now have two dark moon periods each month. At the beginning and end of each month. Looks like I am going to have to pull a Julius Caesar and jack with the calendar! Nah, folks might get upset. So I will just title this next challenge Feb 2.0!
For those not familiar with my challenges each month I present three DSO's for your consideration. An easy object targeted for beginners, a not so easy object for mid to larger scopes from good skies and a difficult challenge that may have you seeking out a 20" scope. Except for the easy object I have either never looked at the more difficult objects or its been so long I don't remember observing. So they are new for me to.
Here we go.
Easy
Hyades
Open Cluster
Taurus
04 26 54
15 52 00
Mag .5
Size 5.5°
# Stars ~380
Amazing this naked eye cluster never received a formal NGC or Messier number. Anchored by ruddy Aldebaran the Hyades is a nice V shaped group of stars easily seen in any sky. Binoculars or a wide field scope reveal dozens of extra stars. Bonus: See if you can see the open cluster NGC 1647 (mag 6, 200 stars) just outside the open part of the V. Would probably be a showplace cluster if not for being in the shadow of the Hyades.
Not So Easy
UGCA 150 (MCG -1-24-1)
Galaxy
Hydra
09 10 49
-08 53 30
Mag 11.5
Size 5.3' x 1'
I want to say I have looked at this galaxy but I'll be darned if I can remember when or where. Anyway, I would normally call this a pretty easy observation but this edge on (33° tilt) galaxy has a bright ~9th magnitude star sitting right on its western edge which will complicate the view. Looks fun. Don't think I am going soft on you with this one. The difficult object will make up for this (evil laugh).
Difficult
AGC 754
Galaxy Cluster
Hydra
09 08 48
-09 38 00
Megastar shows this as Mag10: 15.2 Not sure precisely what this means, maybe someone can interpret.
Size 50'
Number of galaxies: An astounding 92!
This cluster lies just 1° SW of the above UGCA 150. Should be easy to find. But will it be easy to see? The DSS image is astounding with the number of galaxies (this is actually two clusters in the middle of a merger) with quite a few members in the 14th to 15th mag range. Should be visible in a 10" or larger from dark skies. Many are rather small so they should have pretty high surface brightness. Many of the galaxies don't have magnitudes listed but quite a few look to be around 15 to 16th mag. Probably will need an 18" scope to bag these.
As always good luck and let us know what you see!
