A friend of mine, John Berger, here in CN forums has posted a new dead pixel removal script which i think does an excellent job not only of removing dead pixels but for my noisy images also seems to remove a lot of the noise from my images.
Just to give you an idea on how good this is at removing dead pixels and essentially noise in an image here are two side by side examples. first with noise and second without. This is a RAW unedited but STF stretched image of M2.
I should mention this script is not yet signed since we are still both learning our way around creating scripts for PI but here is the link to the repository if anyone wants to add this.
https://raw.githubus...el-Zapper/main/
It is really simple to use There is only one slider bar and it is limited in range from 0.0 to 1.0. i found a setting of .37 to work for most of my images and a setting of 0.3 seems to work on most images. Try different settings and let us both know how this works or if you have any suggestions for improvements.
Thanks and Clear Skies and Clean Glass to all!
Edited by bignerdguy, 07 February 2025 - 07:22 PM.
