Disk in Ha and CaK 2/10/2025
14 replies to this topic
#1 rigel123
rigel123
  • Loc: SW Ohio
Posted 10 February 2025 - 03:17 PM
I didn't notice the Ha image had some thin clouds passing by when I captured until I started processing so a tad "blotchy"!  Just a quick setup and grab before our next winter storm tonight.  It may fizzle out, you just never know!
Lunt LS60T DS
Orion ED80T masked to 40 mm and Lunt BF1200 CaK
Ha
Inverted
CaK
  • bigdob24, hopskipson, Terra Nova and 12 others like this
#2 havasman
havasman
  • Loc: Dallas, Texas
Posted 10 February 2025 - 04:14 PM
Love that filaprom.
  • rigel123 likes this
#3 gstrumol
gstrumol
  • Loc: north of Detroit, Michigan USA
Posted 10 February 2025 - 04:39 PM
Nice catch, Warren!
That's a strange blotch on the left, no? I saw it in mine and GONG's images as well.
#4 LuxTerra
LuxTerra
Posted 10 February 2025 - 10:46 PM
Any additional info on your setup? I have a double stacked LS50Tha, but the diagonal blocking filter bandpass goes off when it's cold. I've been meaning to build a heater and insulated box for it. Any help with how you've tuned your winter setup would be greatly appreciated.
#5 rigel123
rigel123
  • Loc: SW Ohio
Posted 11 February 2025 - 06:57 AM
Love that filaprom.
Thanks!  I would have liked to have done an animation on that filaprom but the cold weather and passing clouds convinced me otherwise!
Nice catch, Warren!
I noticed that too Gary, not sure what was up with that area.
My recommendation is set your scope up and let it adjust to the outside temp and then tune it.  I have used a heater for the BF in the past and still saw the image go off band as time went on.  Then I tried setting up an hour before I ever tried to tune and had no issues getting it on band and it stayed that way during a 1 hour animation.  My Lunt 60mm is a tilt tuned etalon though so not sure how this might work with a pressure tune model.
#6 rigel123
rigel123
  • Loc: SW Ohio
Posted 11 February 2025 - 09:18 AM
A bit gentler processing and work on the variations on the disk.
  • bigdob24, hopskipson, Foc and 2 others like this
#7 rigel123
rigel123
  • Loc: SW Ohio
Posted 11 February 2025 - 09:32 AM
And a crop and rotation of the filaments and filaprom on that SW Limb.
  • havasman and Dale Smith like this
#8 bigdob24
bigdob24
  • Loc: Central Illinois
Posted 11 February 2025 - 09:53 AM
The gentler processing looks great
Dan
#9 rigel123
rigel123
  • Loc: SW Ohio
Posted 11 February 2025 - 10:57 AM
Thanks Dan!  I think I rushed the first batch!  It also shows that strange area on the east limb that Gary referred to a bit better.  Almost like a strange arrangement of the spicules on the surface around that area.
Edited by rigel123, 11 February 2025 - 10:59 AM.
#10 LuxTerra
LuxTerra
Posted 11 February 2025 - 02:56 PM
I will have to try that. Mine is a double stack, so front is a tilt tune and the rear is a pressure tuned. Typically, those filters don't need heated. It's the diagonal with the additional blocking filters that are problematic, but I've never tried to let everything stabilize for that long.
#11 astroflak88
astroflak88
  • Loc: SoCal
Posted 11 February 2025 - 03:09 PM
This looks very nice.
#12 rigel123
rigel123
  • Loc: SW Ohio
Posted 11 February 2025 - 05:33 PM
That was my thought that it was always the BF that was problematic, but an imager from Canada on Solar Chat never uses any heating element on his BF's and does just fine and his equipment gets a lot colder than mine!
#13 rigel123
rigel123
  • Loc: SW Ohio
Posted 11 February 2025 - 05:34 PM
#14 astroflak88
astroflak88
  • Loc: SoCal
Posted 11 February 2025 - 05:41 PM
Is your filter pretty even across or do you have to use flats after/add'l processing?
#15 rigel123
rigel123
  • Loc: SW Ohio
Posted 11 February 2025 - 10:05 PM
I do not use flats.  I get a bit of banding at times if I don’t take a lot of time playing with the tuning as well as the clocking of the DS etalon, but for the most part it is fairly even across the disk.  With the single stack the disk is quite even, the addition of the DS etalon shrinks the sweet spot so it is more of a challenge to get a totally even disk.  A light touch with the Dodge tool in PS helps areas that are a bit darker than the rest of the disk.
