Hi Everyone,
I've got a Meade 628 that has some slop in the RA Axis. I am pretty sure the telescope is balanced correctly, but the problem is when I try to target an object. I let go of the scope, and the ra axis slides just a little bit before it stops (it slides the same amount every time). So if I point at Jupiter, I have to over compensate and move past Jupiter on the ra axis, and then let go and it will slide just a little and jupiter will then stay in the frame. So the ra clutch stops, it just has a little bit of "give" before it will stop. Also, this only happens when moving in one direction on the ra axis. If I move one of the directions along the axis, it will stay put immediately, but if I move the other direction along the axis, it has that little bit of slip before stopping.
I'm told this could be Backlash in the motor drive. I've opened the motor box but there's not many screws that can be adjusted, and everything I have tried does not seem to affect the backlash. Do these pictures show where the adjustments need to be made to fix the slop/backlash? Any help would be much appreciated! Thank you everyone!
