Hello, I have a combination of Meade 8 LX10 EMC 8 inches with Baader UV/IR-cut filter, starizona sct corrector, ZWO OAG (old version) and asi294mm-pro camera. I screwed the filter in front of the corrector because I don't have a filter wheel. I processed 64 exposures with 3 minutes exposure time each, matching darks and flats with Deep Sky Stacker, but vertical shadows can be seen. I tried with and without bias, but the result is the same. What could be the problem and how can I fix it? If I were to edit the recordings with PixInsight: Is there a function that can correct these vertical disturbances? Which one is it and how should I configure it?
Tom.
