My questions are:
- Are the original Nexstar mounts worth upgrading? I've read somewhere that they are better than the SE mounts (better motors, less backlash).
- Is there much difference between the 5" OTA and a 6se OTA? The latter would be brighter, but I wonder if the optics are otherwise comparable.
- What would you recommend?
I would say yes those original mounts were pretty good (but not NS GPS/CPC good) - smoothness/backlash wise. This is anecdotal from the user base and use, but I haven't owned an original NS5/8. I believe that the motor gearbox used was a bit better quality on these earlier mounts.than on the later SEs (so a bit better backlash characteristics). I'm not sure any of this would make much of a difference to a visual user unless you happened to be comparing to a poor mechanical example of an SE (unfortunately not too uncommon).
The optical differences would really come down to the optical quality of each example. The C6s have generally been quite to very good with very few lemons. In addition to the aperture difference the coatings are better on the C6s (they're all XLT) and your much older C5 mirror would likely have degraded a bit so I think you'll easily notice the difference in brightness. So if you're a mixed (DSO and solar system) observer the C6 would be a significant upgrade, if however you have an optically really good C5 and you are primarily a solar system observer then perhaps it wouldn't make as much of a difference.
I think the direction for an upgrade will really depend on a) your budget and b) you're electrical/mechanical capabilities combined with a level of patience.
So if the money isn't really an issue I personally would sell the NS5 and jump over an SE and right to a Evolution 6. While a bit more expensive the operation of that mount is better than the SE and I sense that you might find that really of value to you.
If however you have the expertise and patience to work with the electrics and you want to save some money. then the upgrade thread IMHO contains a great roadmap. I would also seriously consider (as SieglindeFestkochend has) to also add one of Mlord's homebrew DIY boards ... I might even consider doing one if I bought a new Evolution (adding GPS and some additional connectivity options).
But don't underestimate the patience required to go through the board swap - if you get it working first time then fine but you could find that troubleshooting the upgrade sucking up a lot of time and possibly additional monies.
Edited by mclewis1, 13 February 2025 - 09:28 AM.
