Even I am confused with the mount I need to get for C11 Edge HD - Imaging train at around 43lbs, visual at around 40lbs
I was rocking my GEM45 with this, with 40lbs of counterweights, but want to now make do with 10-15lbs of counterweights so thinking about
WD-20 - Both motors are direct drive so no backlash.
Then there is the NYX-101 which is cheaper with similar payload. But user reviews are less than stellar
Lastly you have the proxysky Meow which seems to be the most popular "online" with large user communities.
I have been an iOptron user and absolutely loath the PA routine as it always loses alignment when you tighten the bolts after PA. Have the newer mounts fixed that?
