Hi everyone,
I wanted to share with you all that I was able to attach an Olympus TCON-17X teleconverter to an S50, thanks to the Olympus CLA-13 teleconverter adapter. The whole setup fits together as well as you could hope... for equipment that wasn't designed to go together .
The teleconverter fits pretty snug and although it's front-heavy, it didn't detach even when the Seestar was pointed straight forward and I tapped on it semi-gently. It can definitely be dislodged without too much force so for extra safety I used an elastic tool tether to help add tension and keep it place. In theory, when using a full-size tripod, the tether would also prevent the teleconverter from hitting the ground if it ever falls off.
As far as I can tell, the adapter isn't touching the Seestar's front glass so I don't think there's much risk of damaging the telescope. As you can see, the lip of the adapter is thinner than the lip of the included solar filter.
I'm attaching a picture of Jupiter I took with this setup. It's not great, but it's a lot less pixelated than without the teleconverter. The photo is a stack of a ~6 minute video, taken with these settings: Focus = 1756, Exposure = 2 ms, and Gain = 17
Edited by sergiomo, 14 February 2025 - 12:39 AM.
