The screws are stripped on my "collar" that holds the eyepiece in my 2 speed crayford focuser. I cannot find a place to buy a new one - mostly because I cannot figure out what it is called.
Does anyone know what it is called and as a bonus to me, know where I can buy it?
Just to check: Can you clarify which threads are stripped? Is it the male thread on the visual back where it screws into the focuser, the female thread on the visual back where the thumb screws screw in or the threads on the thumb screws?
If it's an issue with the thumb screws, Bob's advice will fix it. If you don't live in the US, you probably want to use metric because non-metric thumb screws are very hard to source.
If it's the visual back's wide male threads that have stripped, here's one approach: It looks like the visual back from my Sky-Watcher ST80 that I replaced:
I take it that it's from your Sky-Watcher 250P collapsable Dob? If so, I assume it's a 2" visual back rather than the ST80 which is a 1.25" visual back so the threads might be different. Can you measure the thread size with callipers?
For my ST80 visual back, it was 43mm (major diameter) with 1mm pitch. I got a Baader M43x1mm to T-2 adapter (€33):
https://www.baader-p...1a-to-t-2a.html
Once you get to T2, it gives you all kinds of options like a Baader ClickLock or the 1.25" Baader Ultra Short which gives you extra inward focus. Alternatively, there may be a 2" Baader ClickLock thread that interfaces directly to your focuser. Not cheap though...
https://www.baader-p...to-4-1inch.html
Good luck
Tak
