It has been raining for a couple weeks, no stars. Sigh. Then yesterday afternoon I see a note that Io will be transiting around 9pm.
I have been learning how to set up the tripod & mount setup in the daytime with a level & compass, then later N.I.N.A. walks me through a polar align. But with the rain nothing was set up yesterday.
Around 8pm notice some breaks in the clouds, walk out and I can see Jupiter.
Run back, grab tripod, mount, do quick cell phone level & north. Attach scope & lowest power eyepiece. Ask mount to please go to Jupiter.
Mount gets close, and I suddenly realize that instead of using hand controller buttons to center it, can I just use the mount fine adjustment screws?
So I try that, pretty intuitive, just make tiny adjustments to az & alt and presto, Jupiter is centered. Switch to higher mag eyepiece, do it again.
The mount automagically starts tracking when you use GoTo, and over the next couple hours, Jupiter stayed in the field (!).
With all the clouds I doubt that a normal Polaris or multiple plate solve would have worked.
Feeling good, this was my first Io transit (yay!).
But is this actually a way to get aligned? And if not, why not? Is it somehow less good than all the normal methods?
Clear skies,
-Bob
