I made an image of M42 with a cheap Orion 80mm f/5 achromat using an APSc camera with a 0.71x Metabones focal reducer. I was really surprised at how well it came out considering all the chromatic aberration and the simple achromat doublet optics. It worked perfectly on my little SkyTracker Pro. This got me thinking how nice it would be to have a proper imaging refractor. I really want to be able to use it on that little SkyTracker and an optical tube assembly around 3 to 3.5 lbs works with my camera and focal reducer.
I have been thinking about purchasing a used Redcat 51 for wide field imaging. I have seen images made with these small light weight refractors that are amazing and I am intrigued. I can run that on my lightweight SkyTracker. Having a lightweight setup will help encourage me to go out in the backcountry away from my Bortle 7 skies and get better images. Then I stumbled onto a sale right now at Astronomics on the Astro-Tech 60 ED which is a doublet with one FPL 53 element and one Lanthanum element. I really like imaging at around FL 300mm. The Redcat is 250mm f/4.9 the AT 60 is 360mm f/6. Of course I'll need a flattener and AT makes a .80x flattener that is reasonably priced. At .80x I end up with f/4.8 so exposure time is about the same as the Redcat. I like the extra focal length even with the flattener it's still 288mm and having a bit more aperture is usually nice. The AT will also make a nice grab and go telescope for visual, the Redcat not so much.
So I am torn on which is the better path. Theoretical resolution is higher on the larger 60mm scope but whether that will materialize on a camera is another thing altogether. The primary use will be imaging but the notion of having the ability to use it visually with good results is nice.
I am trying to stay at around $500ish budget, that's why the Redcat is used and the AT 60ED is new. Is the Redcat's premium Petzval optical train that much better than a quality ED doublet with a flattener? Which would you choose and why?
