Hello All,
I will be sending my scope to a remote hosting facility very shortly. I will not be using a rotator and will do mosaics. I have never done mosaics before. I plan to set the chip at 90 degrees and just do mosaics when i need more FOV for a target. I will be using a spacecat 51 and a 2600mc with an AM5 and ASIAIR. I will be using astro pixel processor for stacking, I will also be using the ASIAIR mosacing tool to plan and create these mosaics. How difficult is mosaicing really? it seems daunting to get a 4 panel mosaic for instance to have no seams and be evenly illuminated.
I would like to know the finer points of mosaics. For instance, I was told I should take all frames each night and do this every subsequent night. It was explained that this was to ensure that frame 1 would have the same illumination differences as frame 2,3 or 4 for example. i could add more frames each night, but each nights set should be uniformly illuminated when i stack them if each set of 4 subs were taken each night. This seems like sound advice. Another tip was to overlap at least 20 percent.
What do you do if you lose many frames from a single panel (clouds etc) i would imagine that if one frame had less subs that would be an issue to ensure no seams due to brightness differences. I would imagine noise would be different from the other frames. How do you recover from that?
Any advice and tips you can give me would be appreciated. I have never done mosaics, so im pretty much a blank slate. If anyone has tips on stacking in APP that would be great as well.
Thanks in advance to this amazing community!!
Skyhunter1
