Has anyone tried a 130mm f/5 reflector on these mounts and what were your findings?
Michael, well, kinda. I had the SV225 out for a first light on the 7th. The picture has me with the AT102ED mounted, but I actually used my C130SLT tube mounted on the SV225 setup. I found it a bit too wobbly, but I haven't done Jim's (Polyphemos) modifications. I've been putzing around with other alt-az mounts after this, so need to bother to take it apart and run to the hardware store, which I will eventually do. I believe the essentials of the SV225 are solid, but, yeah, probably the minor updates he and other contributors to his thread outline will improve things mightily.
FWIW, I have found that the C130SLT is, overall, easier on mounts than the F/7 AT102ED. The AT102ED is quite heavy, compared even to my C102GT F/10 achromat. Although the moment arm for the C102GT is greater, I am certain, given it weighs in something like 60% of the AT102ED, it would be easier to mount than the AT102ED. And the C130SLT is, in my opinion, more like the C102GT than the AT102ED. So, assuming I bother with the minor and necessary updates Jim, et alia, outline in his thread referenced above and these mods work (and I'd bet they will), yes, the SV225 should easily be up to the task of handling a Celestron, or similar weight 130mm F/5 scope. But you'll need to fix the bloody lock nuts goof-up that SVBony has implemented. But that hardly sounds problematic. A small investment in precious time, yes, but even for someone as generally bad at engineering as me, not really a problem.
