I have recently picked up the Apetura 6" RC scope for my larger sensor, longer focal length imaging scope hopefully. I enjoy the C6, but the baffle tube is just too small to fit any descent sized camera and OAG on reliably enough to be a full remote imaging setup for me. I hope this RC can cure that issue.
I see many images with this scope and people using the asi2600 (no duo) with great results. I have measured the baffle tube and it appears to be ~41mm-42mm in size at its smallest point. This is roughly 5"-6" away from the camera sensor, or more, and I understand that baffle tube size does not equal image circle size. The 2600 Duo advises an image circle of 44mm minimum to use the setup. I know I can cut it closer with a conventional OAG setup, but I'd like the simplicity and reliability of the Duo setup as this is expected to be a full hands off remote imaging setup when complete. Does anyone have any advice on if I risk it for the biscuit?
I know not many people are running this scope to start with, and I can find no one posting on Astrobin with this scope and the 2600 Duo yet (Unless they are just mislabeling it as a standard 2600 maybe?) I'm sure alot more are running the 8" Apetura and GSO versions, do you guys have any image circle issues with full frame cameras? I would assume if you can run full frame with no issues, I could run the Duo which should need around the same image circle.
Edited by Sean13, 17 February 2025 - 12:34 PM.
