Explore Scientific IEXOS-100 or DIY OnStep EQ5
DIY EQ Mount
1 reply to this topic
#1 woqwoq
woqwoq
Posted 17 February 2025 - 12:15 PM
Hi everyone,
Recently I have bought an absolute bargain of a combo for €100: It included a brand new Bresser EQ5 style mount and a 102/1000mm scope.
I'm planning to use one of these mounts with SvBony SV503 80ED scope and a Canon 600d with a 30mm guiding setup for astrophotography. This setup would weight around 5-6kg, which is pretty much the limit for the IEXOS with the upgraded tripod.
Being my first ever mount, do you think I should make my own GoTo system using OnStep for the EQ5 or just get the IEXOS-100 and use it overloaded (as the OnStep might be tricky to get to work initially)?
Also, if you have any experience with using a DIY EQ5 OnStep, please share your feedback.
P.S: I guess it's worth to add that I do have a 3D printer and I do have experience with electronics and arduino.
Edited by woqwoq, 17 February 2025 - 12:17 PM.
#2 hcf
hcf
Posted 18 February 2025 - 12:06 AM
Go with the EQ5 you will be well within the weight limits of it.
Get a Terrans Industry Onstep V4 Pro motor kit, I guess your mount is the EXOS2, so get the EXOS 2 version, will take you less than 30 min to attach it to the mount. Costs around $150. If you really want to do your own controller later you can keep the motors pulleys belts and brackets and build your own controller.
Also tagged with one or more of these keywords: DIY, EQ, Mount
