The "ring of fire" along the field stop is an overcorrection of the eyepiece design, not an aberration of the exit pupil.
This sort of overcorrection has been used for the eyepieces compensating the chromatic magnification difference of the old style APO microscopy objectives.
My ultrawide (85°) f=30mm, Carl Zeiss West Germany, Erfle II design, is free from the ring of fire.
I have checked all of my eyepieces for the color fringe along the field stop, even if it does not play role when observing the DSOs.
For some people, the visible color fringe indicates of how much attention has been paid to the optics design, glass materials choice, manufacturing costs, etc.
Best,
JG
Is your Ultrawide 30mm free of off-axis astigmatism at F/5? I think the design and materials choices of the 31mm Nagler are based on providing the sharpest stars off-axis. The 31mm Nagler in the NP-101, it is an awesome view, a perfectly flat 4.5 degree field, stars as sharp at the edge as they are in the center. I see no CA.
It was not designed for day time viewing.. The 35mm Panoptic excels during the day.
I personally think the Ring of Fire is a design decision. The 20mm Type 2 Nagler used the basic type 2 Nagler design, 8 elements and was massive, the heaviest production TeleVue eyepiece ever, 2.30 lbs, 1043 grams. A 31 mm Nagler of the type 2 design would be even more massive, at least double the weight. The 31mm Type required a new design.. The 6 element Type 5 design is much lighter. The 20mm Type 5 only weighs 1.04 lbs, 472 grams. The 16mm Type 2 and the 16mm Type 5 are very similar, the ratio for the 20mm are 2.21, the 16mm, 2.27.
Apply that same scaling factor (2.21) to the 31mm Nagler and the type 2 design for a 31mm eyepiece would be 5.1 lbs, 2300 grams..., Obviously not practical.
The other well corrected, long focal length 82 degree eyepieces (30mm ES, 28mm UWA) follow the 31mm Nagler design, 6 elements and they also show the ring of fire during the day.
In my way of thinking, the reason it is not seen at night is that it is very low contrast, very dim. It is seen during the day as a faint cast over the existing image in the very outer field, color vision has a much greater dynamic range during the day...
Edited by Jon Isaacs, 20 February 2025 - 04:01 AM.
