Wow, that was cool! You are far better at that than I am.
Real dimensions: the ones that matter are these, I guess:
Losmandy dovetail - I am measuring an existing dovtail (not clamp):
73 mm at the widest
64 at the narrowest
it is 10 mm high. The angle should be 60 degrees (https://www.cloudyni...pecs/?p=5216270)
Vixen dovetail:
43 mm at teh widest
37 at eh narrowest
14 mm high
Magnus
Happy to help.
Though it would take me only a few minutes to do this kind of stuff, it would take me far too long to figure out the full dimension's needed to model it such that you'd be happy with it.
Yes, I can 'assume' some but, experience informs me that some would need to be tweaked... You say "...the one's that matter, I guess"... therein lies the Rub...
I need 'All of the geometry' dimensioned. I don't like guessing and re-working...
Attached PDF is for you to mark-up... pencil is fine. And attach to the post or post Screenshot/photo.
Leave Nothing un-dimensioned. If it's a dimension you don't care about, I still want one or, you get the dim's that I conjure up and I don't want to be re-working it...
Also, as I look at the image you posted, it looks like the Edge on right-side is Vertical (not 60º) and top edge is chamfered...?
And, the Threads for your Knobs? I can put Printable threads in the hole but I need the Thread size (M4...M6...etc or other. Or, just holes for you to Thread with a Tap...?
So, Please, put a dimension on Every line...as if you were modeling it.
Oh, and 'Quote' my post/other or I don't get notified of your Post/Response...
UPDATE:
Over morning Coffee, I modeled the shape using your Dimension's.
I did it to show, by example, why I want 'you' to provide all dimensions, hoping you'd discover the 'mathematical incongruity' of the Dim's you posted. Perhaps you've discovered them by now...
The image posted below shows that the 64 and 37 (the Narrowest) are Not possible if the other Dim's are as you posted... Not to mention your posted Photo with it's geometry unrelated to the Link you posted.
That said, the STL file for printing is attached. Unlikely it will be useful beyond a paper-weight...
Hum.stl 2.23KB
2 downloads
tofu.pdf 108.46KB
3 downloads
ADDITIONAL UPDATE: Only to amuse myself...and to show what could be done quickly (in FreeCAD). I inverted (the Part) and added two M4-Thumbscrews.
Image attached... The STL is too large for posting here (the Thumbscrew-Threads cause this)
I deleted the Thumbscrews and now post a smaller STL
I'll leave this Topic alone, now...
hum-Body003.stl 3.01KB
0 downloads
Edited by whereIsIt, 19 February 2025 - 02:37 PM.
