Hello, I use an Arcturus binoviewer with an 2” 2x barlow (equivalent of 2.75x Barlow in real life) to reach focus with my 12” f5 dob. I use it mainly for planets and the moon but also for stars clusters and bright/small DSO.
Due to the 22mm clear aperture of the bino and the high magnification that the focal length + Barlow gives me, the biggest eyepieces field stop I can use are:
-25mm plossl 48º (165x)
-18mm APM UFF 65º (230x)
-14mm ES 82º (295x)
But in the real world: all those 3 eyepieces gives me the same real TFOV (~0.28º) with different magnifications. And my goal is always to stay at that maximum field stop range, as the magnification is already considerably high. So the question is, should I just keep one of them as they gives me “the same”?
I’ve been using the bino for almost a year and almost every time the 14mm 82º is the one in the bino.
The 18mm and 25mm are a different experience, as the magnification is lower, but the amount of sky I see is the same, and changing eyepieces in the bino is a bit of an inconvenience… (And someone just have offered me $160 for the 18mm pair).
So, should I just keep the 14mm 82º and say (just because they’re cheap), the 25mm plossl?
Also, if I want more magnification (which I rarely do), i can increase the distance from the bino to the barlow.
Do any of you follow the same strategy? I see multiple people with a dozen eyepieces for the bino, and I won’t want to be like that hahaha.
For monoviewing I’m served with 25, 14 and 9mm ES100 + barlow.
Note: I DO like big AFOVs as you can see, and I find the 14mm 82º really comfortable on my binoviewer, even more than the UFF 18s due to the bigger width of the last one.
Thank you.
Edited by Cielo_nocturno, 21 February 2025 - 04:51 AM.
