I have been working on a 1980s Super Polaris mount for my C8. Some of the nuts and bolts have some surface rust that I have removed the rust as follows
1) Soak in vinegar for 1 day
2) Scrub with brass brush and re-soak if necessary
3) Clean metal with borax and rinse thoroughly
4) Dry and spray with WD 40 to remove remaining moisture and temporarily prevent rust
Some of the hardware still has its original finish on it, while it has corroded off in places on others. I was going to apply a light oil to prevent further rust, but they leaves an oily residue that I know will find its way onto an optical surface. I have been told to try wax.
I thought that I would ask this group what their recommendation is. I could easily replace some of the hardware with new stuff, but it would not match and it would drive me nuts. Any thoughts on different rust removal techniques would also be appreciated.
dan
