I hope I am putting this in the right category. If not, please guide me to a better category.
I have a bunch of vintage telescopes and since some are stored in air-tight Pelican-type cases, I worry about mold or mildew getting started inside the cases.
I had been using large desiccant bags, but then I read that they generate a very fine particulate dust that can bond to optics on absorbing moisture and can be really hard to get off and can even damage coatings. While I have never observed this happening myself, I wanted to bring up the subject here to learn what others are doing to minimize moisture.
I read about something called a "dry golden rod", have any of you tried these and how did you like it? Any tips on best usage?
i have also seen metal dust plugs where one can unscrew the top, add desiccant, and then stick that into a focuser to absorb moisture. Any feedback on using these? Is there any type of desiccant that's better than the others or are they all pretty much the same?
If you don't mind me asking, what all are you using to minimize moisture and prevent anything from growing inside the case or on your equipment?
Other than UV light and dehumidifiers, what else can I do to keep my optics safe and dry?
Thank you so much in advance, I really, truly appreciate your help with this!
