So here is my mount like yours is. I removed the gasket (which is a clear plastic one I made), and you can see the brass wedge.
At this point, the RA axis turns very easily. This is why the scope and counter weights should be removed. You'd have no control over them.
Also, the yoke part of the mount should be able to lift off and be separated from the rest of the mount attached to the tripod. You don't have to lift it off at this time.
If you think the mount needs cleaning, lift the yoke off and it will look like this:
You can see that the brass ring gear moves up and down, but it will not fall out. The worm gear is holding it in place. The split ring can easily be removed, but do it carefully.
If you want to clean things more, you have to loosen up the worm or take it out. Caution, the worm gear, if it has never been messed with, may be set in the correct position as it came from the factory. On both sides of the worm gear the are eccentric adjusters or cams held in place by two set screws for each. The turning of those adjusters positions the worm gear against the ring gear. It is not fun to play with, and it drives me nuts trying to get it right. Try to remember or record the position of each cam when you go to put it all back together.
But you may want to clean the ring gear and the worm gear and replace the old grease.
Another guy here on CN did a thread on repairing and adjusting these mounts. On first try I couldn't find it, but I'll look again.
I found it. Here is the other thread. It's worth a look:
https://www.cloudyni...sco-3-eq-mount/
And now that I've looked thru that thread, Preston explains things a lot better.
Edited by Garyth64, 02 March 2025 - 08:34 AM.
