Your OSC camera already has RGB filters in the bayer layer. So the UV/IR filter you’re using is in addition to those. It’s for filtering out the wavelengths (CA) that most refractors can’t properly focus. Did you know that you don’t need to use a UV/IR filter with your RC? The only case is if you’re using a reducer or flattener that has some CA.
You can create a synthetic luminance layer from your data. I’ve tried it, but never had any luck with it improving my image. Works much better to use a mono camera. Since you have so many scopes and mounts now, you should think about getting one. Using it to supplement your OSC camera with L or Ha data is an easy way to get started with it. The image above I shot with a 2600mc on one scope, while another scope was shooting Ha with a mono camera.
Thanks Droth.
My RC10 has an Astrophysics 0.67 reducer thats made of glass, so I thought a UV/IR cut was still required ? unsure about this.
Just thinking about your suggestion of buying a mono camera to collect Ha Data .
to be honest I never have a shortage of Red (Ha) in any of my images, so I have never thought that getting more red would be an improvement.
I also notice that many people shooting with Ha filters, or duo bands, seem to present Red dominated images, which look amateur and entirely one dimensional to me. I don't like the look at all. (I am talking about Nebula shots mostly)
currently i feel my OSC camera does pretty well with only the UV/IR cut. the colour balance also looks good to me.
Q1. if a mono cam was used to shoot luminance only, what type of filter would be required to do this ?
Q2. What would be advantages ?
Edited by Spaceman 56, 28 February 2025 - 07:16 PM.
