Do NOT start taking your mirror out or taking things apart just yet. To see if your mirror is binding, just try to lift the mirror from behind. A gentle but firm push, slow and steady, on the back of the mirror glass is all that's needed. the mirror should be able to lift at least a tiny bit off its pads, and swing around a bit on its sling. If it's working properly, you will see how the mirror cell adjusts to support the mirror. It will shift a bit under the weight of the mirror. Your mirror is kind of heavy (maybe 12 pounds?), so I recommend doing this with the scope pointing close to horizontally, so you're not trying to lift the weight of the entire mirror. It should swing away from the pads, supported by a sling that wraps around the bottom half of the mirror. If it can't be pushed away from the mirror cell support pads, it may very well be bound up by the safety mirror clips.
The mirror clips are not really used during telescope use. They are there to prevent the mirror from falling out of the scope during shipping, transport, or some calamity. That is why they should be a little bit above the surface of the mirror. There to catch the mirror if something goes wrong, but to stay out of the way during normal use. Kind of like a spotter for a gymnast.
If you find the mirror is held solidly in place, spend some time studying the mount to understand better how it works. Also, seek advice on assembly/disassembly from the place you bought the scope from. Most telescope stores should be helpful with this type of thing.
My telescope has felt pads on the cell, and I was having some problems. Someone showed me this trick, and showed me how the felt had become stuck to the back of the mirror, and was causing a bit of distortion.
