There's a 1.25-inch Celestron eyepiece and filter kit that I heard was essentially worthless. A sentiment that frequently appeared on CloudyNights (CN). So, one day when I felt that I hadn't ordered anything astronomical in quite a while, I decided to order the kit to see for myself just how horrible the contents were -- I still have the case and its contents, though the contents are now scattered about among my other eyepieces, etc. in other cases
My assessment? The kit is perhaps the most underrated set of eyepieces ever to make an appearance on CN. Everything in that kit is of decent quality, and yes, I've used every item that the kit contains.
Sure, one can condemn the shorter focal-length Plossls in that kit, but a Plossl is a Plossl, and any short focal-length Plossl is going to have little in the way of eye-relief. But even those shorter focal-length Plossls are perfectly usable. It's not necessary to get one's eye close enough to see the entire field of view in order make good use of them. And of course, the kit also contains longer focal-length Plossls which have greater eye-relief.
I just got out the 32mm and 6mm Plossls to double check on the coatings -- and it appears that every air-glass surface in those eyepieces is coated! These are good, high-contrast eyepieces!
If one had to get by cheap with a full set of 1.25-inch eyepieces, that kit would do the job as long as you're not so spoiled as to feel that you have to have greater eye-relief or larger than 52 degree apparent fields of view (or a more prestigious name on the eyepiece).
Those eyepiece work and work very nicely -- as long as a person is OK with using Plossls.
Thank you!!!!!!
I would agree 100% with this. I used to have that kit, and read some of the reviews which really made it sound horrid. It was fine, my only gripe was the inclusion of the 4mm Plossl, which most people struggle to use - had they included a 20mm instead, the set would be excellent IMHO - but even as is, its fine. Perhaps a little over priced - but if you get it discounted or second hand, its a no brainer -
I think the criticisms i read about the kit, and many other sets of plossls, is that they are, well, plossls. And some people really attack the design, regardless of focal length. People view them as entry level, and very basic. But a good plossl is sharp, and i think people forget that. Honestly, some of the best views i have had have come with plossls. Yes they are narrow. And yes the eye relief is tricky when you look at shorter focal lengths - but i wouldnt be without them.
Its a shame, but people view it as a bare minimum, and merely a stepping stone. And thats why they end up being sold on second hand quite a bit
I have a set of Tele Vue Plössls which I love and then on a whim I bought a set of Celestron Omni Plössls. That entire set of Celestron eyepieces cost less that the price of ONE of the Tele Vue Plössls! Yet they perform fine. They have blackened edges and barrels, full multi coatings and provide sharp, contrasty images. Are the TV's better? I'd say yes. Are they 10x better? Not at all. Incrementally better would be how I'd put it.
But could I use those Celestron Plössls as my only eyepieces and be happy? Absolutely. The optics in these Omnis is probably identical to the optics in the eyepieces in the Celestron Eyepiece and Filter kit.
Unless its Tele Vue - if its a Tele Vue Plossl, people love it.
Its very difficult for me to imagine Tele Vue releasing an accessory, and it NOT being widely discussed as the greatest version of that accessory. Need a Clip to hold your coffee flask to the based of your tripod? Try this new Tele Vue Coffee holding adaptor - some time later -
- "well all i can say, is this is the best flask holder iv ever used, well worth 200 dollars"
I understand its not just brand loyalty, and yes TV quality is fantastic. There is no doubt about that. Iv used their plossls, and they are a slight cut above the rest. But at least from where i am standing, they arent worth the incredible price difference. 'Incrementally better' should be Incrementally more expensive. I spent about 300 euro collecting my vintage set of Series 4000 Japanese Meades - i view them as fantastic, and possibly slightly better than their modern day equivs. Had i instead chose to chase the TV Plossl set, id maybe have 3 by now - They might be a bit better, but i wouldnt have the focal range i prefer -
From where i am standing, the TV plossl line (full set up to and including the 55mm) would cost as much as a brand new near complete set of Morpheus eyepieces - about 1500 euro - Couldnt justify that expenditure
Edited by hal9500, 12 March 2025 - 05:48 AM.
