Recently, as my eyes are showing signs of aging, I’ve taken to binoviewing. I am using a Baader Maxbright II and a 1.25” T2 Zeiss spec prism diagonal with a 1.7x GPC. I’m currently using these with both my Takahashi TSA-120 and an FC-100DF, however, I am awaiting a TEC 140 f/9.6 later this year. The TEC is natively BV friendly and will likely not need the GPC to reach focus. I'm looking for some suggestions about eyepieces.
If you were starting from scratch with the above BV/diagonal, and had the TEC 140 f/9.6 coming, what eyepieces would you purchase? I’d appreciate suggestions considering the following criteria:
Eyepieces should be readily available
Comfort is important to me and while I do not use glasses at the eyepiece, I do want to be able to see the full FOV without having to press my face into the eyecup or get eyelash oil on the lens.
I will use the BV’s for everything (DSO observing, some double star work, and the usual lunar and planetary suspects)
Here are the eyepieces I have been using and what I think about them:
30mm Celestron ultima series (the original ones), easy to use, good enough, not convinced the overall image is as good as the TV plossls below
25mm Televue Plossl, easy to use, overall an excellent image. I reach for these 95% of the time over the 30mm ultimas
15mm Celestron ultima series (the original ones), very tight eye relief, seem to deliver a pleasing view, however difficult to appreciate the full FOV due to tight eye relief
7mm Televue Delite, had to “decloak” them to allow use with my narrow IPD. Image is good however not as easy to hold position with the uber wide eye lens
Hope that provides enough background (or too much!) for eyepiece recommendations.
Cheers
