I believe that the mounts for the Meade 6" and 8" telescope were the same in their time period. I do know know their time period.
About 3+ years ago I purchased a red Meade 826, it is identical to the Tasco 38T. I cleaned it up, tested and had the primary recoated, put in a larger Antares secondary, changed the secondary support and spider, and changed the focuser to a similar one.
But I never messed with the mount.
Last year, I purchased a basket case white Meade 826. I repaired a hole made in the tube, cleaned the mirrors, but it still needs some work to be usable.
I never messed with its mount either, until a couple of days ago.
I brought both mounts in from the garage. The one on the left is the mount for the white Meade, and on the right is the mount from the red Meade.
I wonder which mount was a first design? I think you can already see a couple of differences. The castings are basically the same.
In this picture, the RA shaft is longer on the red Meade mount (the black one), because the RA circle has been moved.
In this picture, you can see the the black mount has a latitude adjustment:
The clock drive on the red Meade black mount works fine. (Well, I can hear it run.) The unpainted mount's CD does not work. Water got into the housing sometime in its life.
I decided to take the unpainted mount apart. First thing was to remove the ring hear and clutch assembly. The last section would not move, so I pulled it off like a gear:
In doing this, I was afraid I would break the part in trying to get it off, but it did come off. The collar was also difficult to take off.
Before I pulled the shaft out of the housing, I filed and sanded the rusty end of the shaft. The shaft came out easily.
I was surprised to see that there was a bearing at the top of the housing. I didn't know these mounts had a bearing. I thought they only had sleeves like the Star Finder mounts.
I didn't take any more pictures. It was just doing some cleaning and re-assembly. I also took some fine sand paper and sanded the end of the shaft like I was polishing the end of a boot. All traces of the surface rust disappeared. Before I re-installed the clutch assembly, the RA shaft would easily swing back and forth like a pendulum on its own.
Even though the CD is missing from this mount, it still has the slo-mo adjustment, which is the knob sticking out of the CD cover. This mount could still be used manually.
Next thing to clean now will be the pedestal:
Edited by Garyth64, 02 March 2025 - 08:35 PM.
