Daystar Quark Solar Imaging. Aperture reduction?
Solar Astrophotography
15 replies to this topic
#1 alwaysreview
alwaysreview
Posted 10 March 2025 - 02:04 PM
I got first solar imaging with AT60ED, Daystar Quark Chromosphere model (4.3 barlow), 1.25" 0.5x GSO Focal reducer, and ASI174MM. See image in below link
https://www.astrobin.../full/yiu5z6/0/
I see that the quark works best at F30+ whereas my setup is less than F30 (6x4.3 = 25.8). Would aperture reduction make the contrast better?
Edited by alwaysreview, 10 March 2025 - 02:45 PM.
#2 bigdob24
bigdob24
  • Loc: Central Illinois
Posted 10 March 2025 - 03:31 PM
This image is off, need to work on tuning.
Have a look at GONG images for the day and tune until you bring out all the details you see there
Dan
  • EVS likes this
#3 gstrumol
gstrumol
  • Loc: north of Detroit, Michigan USA
Posted 10 March 2025 - 03:45 PM
First, welcome to CN and your first post!
What Dan is referring to can be illustrated here:
(click to enlarge)
The GONG image from this morning is on the right; yours is on the left with the color removed. You can see you're missing a good bit.
Since you have a Quark, I'd guess the problem is that you are on the wrong setting. You need to run through everyone of them (first time) to see what you get. When you change a setting, you have to wait until the light turns green again (maybe 10 min or so) before examining the image.
#4 alwaysreview
alwaysreview
Posted 10 March 2025 - 09:37 PM
Oh, wow. Thank you for the reference! I will try every click this weekend and post it here! Thank you :)
  • gstrumol likes this
#5 hopskipson
hopskipson
  • Loc: Queens, New Yawk, Light pollution Headquarters!
Posted 11 March 2025 - 04:40 PM
You are also right that an aperture mask will help with contrast by narrowing the bandpass.
#6 alwaysreview
alwaysreview
Posted 12 March 2025 - 01:34 AM
Understood. I will try to make DIY aperture mask as well!
#7 CHASLX200
CHASLX200
  • Loc: Tampa area Florida
Posted 12 March 2025 - 06:18 AM
NO CUE HOW A QAURK WORKS or what kind of scope is best.
#8 hopskipson
hopskipson
Posted 12 March 2025 - 08:13 AM
The Quark uses a mica based etalon at the focuser end of the scope. It needs parallel light so it has a Telecentric to provide that. To get on band it has a heating element that heats the etalon. To get to the desired bandpass you need to have a focal ratio between 30-35. The Quark’s Telecentric magnifying power is 4.2 so a F/7-9 scope is ideal
#9 CHASLX200
CHASLX200
Posted 12 March 2025 - 06:39 PM
I guess that means no low power views.
#10 hopskipson
hopskipson
Posted 12 March 2025 - 06:52 PM
No, you can use a short focal length scope. Something like a ST80 @ 500mm focal length, masked to 60-70mm and a 25 mm eyepiece for a full disk.
With a Quark you change telescopes to adjust magnification whereas with a dedicated solar scope you change eyepieces. With the quark you can increase your aperture not so with a dedicated solar telescope.
#11 C0rs4ir_
C0rs4ir_
  • Loc: Germany
Posted 13 March 2025 - 07:39 AM
Actually yes. Trying to get low power with a Quark is like trying to get wide field views with a sct. Its not designed for it.
Edited by C0rs4ir_, 13 March 2025 - 07:39 AM.
#12 gstrumol
gstrumol
Posted 13 March 2025 - 08:21 AM
That's true for the ones that have a 4.3X Barlow built in. But isn't there one that doesn't have the Barlow?
#13 C0rs4ir_
C0rs4ir_
  • Loc: Germany
Posted 13 March 2025 - 11:54 AM
Yes but still you need at least f/30 to have good performance of the etalon. You can work with less, but at the cost of contrast.
http://www.astrosurf...mica-spaced.jpg
Edited by C0rs4ir_, 13 March 2025 - 12:07 PM.
#14 TareqPhoto
TareqPhoto
  • Loc: Ajman - UAE
Posted 16 March 2025 - 08:20 AM
I have the Quark without built in Telecentric Barlow, i can use it nicely even not at f/30, but my seeing is different.
#15 alwaysreview
alwaysreview
Posted 16 March 2025 - 01:51 PM
Sad news. I accidentally put quark on 12V power supply and it fried the unit. I pulled it the second I saw smoke coming out of the microusb port but I lost the LED light and it seems completely dead.
I just sent email to daystar asking for how much would it cost to fix it..
#16 TareqPhoto
TareqPhoto
  • Loc: Ajman - UAE
Posted 16 March 2025 - 09:56 PM
Sorry to hear about that, i hate when those accidents happens also.
Anyway, i hope Daystar will answer you soon for the repair or fix, meanwhile test it by using a dew heater, maybe that can do the job somehow, i once tested my Quark while it was off because my weather is hot or warm and i was on band even the Quark was off, so try to buy a dew heater that has controller of different temps and try before you send it or until you wait Daystar response..
Also tagged with one or more of these keywords: Solar, Astrophotography
