Tube Rings - Lightweight - Carbon Fiber Composite - 50+ Models & Sizes
9 replies to this topic
#1 Rouzbeh
Rouzbeh
  • Loc: Canada
Posted 11 March 2025 - 04:24 PM
ROUZ ASTRO - Tube Rings
50+ Models & Sizes
Available for Takahashi, Astro-Physics, Celestron, Sky-Watcher, TEC and more...
LIGHTWEIGHT - less than half the weight of cast metal
IMPROVED RESULTS - significantly increases mount performance & image quality
CARBON FIBER COMPOSITE - CAD designed & produced using the FDM process (fused deposition modelling)
ARTICULATING DOUBLE HINGE  – powder coated stainless steel  - rings "wrap" around tube for extra grip
MACHINED KNOBS – CNC hollowed & knurled aluminum red (with hex bolt)
MODULAR DESIGN- various compatible & lightweight dovetails and handles
NO PAINT or ANODIZING- that can chip or be scratched off
Strength
STAINLESS STEEL RECEPTORS - all bolts threaded into implanted receptors
LOAD TESTED - for various scenarios with hundreds of pounds of load (see videos)
ENGINEERING GRADE MATERIAL - composite of high modulus carbon fiber & polymers fused at high temperatures over 540 deg F (no glue or epoxy is used)
EXTRA HEAVY DUTY - versions also available or 3x rings sets
Link:
https://rouzastro.co...ory/tube-rings/
  • havasman, fmendes and wolf man like this
#2 Rouzbeh
Rouzbeh
  • Loc: Canada
Posted 11 March 2025 - 04:28 PM
Some customer examples:
Link:
https://rouzastro.co...stomer-gallery/
  • Jim Waters likes this
#3 DLuders
DLuders
  • Loc: Spokane, WA
Posted 11 March 2025 - 04:29 PM
It's great that your Tube Rings are available in a bunch of different sizes waytogo.gif  , since Orion Telescope went out of business and no longer offers its rings.
#4 norvegicus
norvegicus
  • Loc: en route
Posted 11 March 2025 - 04:47 PM
so... 3D printed?
#5 Rouzbeh
Rouzbeh
  • Loc: Canada
Posted 11 March 2025 - 05:05 PM
Available as pair, single, or triple ring sets
Edited by Rouzbeh, 11 March 2025 - 05:16 PM.
#6 Rouzbeh
Rouzbeh
  • Loc: Canada
Posted 11 March 2025 - 05:20 PM
Glad you think so.
We are adding sizes regularly and also have the fully custom size builder page here:
https://rouzastro.co...gs-custom-size/
From 3 to 12inches.
Here is a custom setup with a large 180mm refractor ring set, on top if which there is another 140mm OTA:
  • Mike G. likes this
#7 Rouzbeh
Rouzbeh
  • Loc: Canada
Posted 11 March 2025 - 05:23 PM
so... 3D printed?
There are 70 individual parts in a pair of these rings.
Body parts are FDM printed carbon fiber composite (engineering grade with high modulus carbon - not generic consumer grade), internal hardware is CNC machined stainless steel, powder coated stainless hinges, Aluminum T6061 anodized knobs.
Edited by Rouzbeh, 11 March 2025 - 05:28 PM.
  • norvegicus likes this
#8 Rouzbeh
Rouzbeh
  • Loc: Canada
Posted 11 March 2025 - 05:25 PM
Strength example of a small 4inch ring:
Video link:
https://youtu.be/mv3...QOWSON583kzn2W5
#9 norvegicus
norvegicus
  • Loc: en route
Posted 11 March 2025 - 06:06 PM
Very nicely done.  I print a lot so I appreciate the care you've taken. This is a great application for FDM that fulfills a real need in this community.  I wish you success and the best of luck.  waytogo.gif
Edited by norvegicus, 11 March 2025 - 06:07 PM.
#10 Rouzbeh
Rouzbeh
  • Loc: Canada
Posted 12 March 2025 - 12:09 PM
Thank you, we appreciate your kind wishes and value your feedback!
