HEQ5 PRO Dec axis freely rotating with clutch on
#1
Posted 12 March 2025 - 04:06 AM
#2
Posted 12 March 2025 - 05:25 AM
Try this: Take the screw for the DEC lock nut off and remove the handle. then turn the DEC lock screw down further. there is a small brass disc inside the channel where the lock nut is at. if that lock nut becomes loose or the brass washer gets worn it might do that. Taking the lock arm off will let you tighten the lock nut down further. If you cant tighten it down to where it locks the DEC axis take the nut off and look inside and see if there is a small brass washer inside the channel. if not then it somehow went missing. It shouldn't be it may simply be a loose locknut. See the following video for what i mean:
https://www.youtube....h?v=rsr7m1ejjVU
The video does a complete teardown of the DEC axis of the HEQ5-Pro but the part you want to pay attention to is the lock nut removal and removal of the brass washer inside this section.
#3
Posted 12 March 2025 - 06:49 AM
I tried but it doesn't seem like the lock nut is loose or the screw is not tight enough. I think that maybe when i was calibrating the top set screw the worm gear might have disengaged with the big brass gear...
#4
Posted 12 March 2025 - 07:10 AM
Just to clarify i opened the side of the mount and tried to control the dec axis with my hand controller, the gears turn but the actual axis doesn't move.
#5
Posted 12 March 2025 - 12:23 PM
If the motor gears are moving when directed to do so by the hand controller and the Dec axis doesn't move, then somewhere in the gear train a gear is not meshing. This is most likely, from your initial post, because the worm gear is not engaging its mating spur gear. This should also cause the DEC axis to rotate freely when the DEC lock is engaged and you try to rotate the DEC axis using the saddle.
#6
Posted 13 March 2025 - 09:42 AM
Edited by marco masento, 13 March 2025 - 09:43 AM.
- bignerdguy likes this
#7
Posted 18 March 2025 - 05:53 AM
