Star Trail problem after Polar Align (NINA 3PPA)
Equipment Imaging Mount Polar Alignment
6 replies to this topic
#1 astro_susa
astro_susa
  • Loc: Torino (Italy)
Posted 12 March 2025 - 11:53 AM
Hi, I had opened a discussion a while ago about star trail problem and since it's still not solved, I wanted to add some information and images. I would like to understand why I get star trails with even just 20sec poses, after doing polar alignment with NINA's 3PPA plugin. I'm not using the guide yet (I will shortly) but I'm not sure if that could be the only problem. I have prepared images to compare on Hamal with different exposure times, before polar alignment and after polar alignment. The 'pre polar align' images I made after I leveled and turned the mount to North, set the zero position and performed a goto on Hamal. The 'post polar align' images I obtained after running the Three Point Polar Align plugin with NINA (I can't see Polaris) which as a final result gave me a total error of 30sec, an operation that cost me a lot of time and patience. The 'post align' images look even worse than the 'pre align' ones. Do you think it can be due only to the fact that I don't use the guide? I am left with strong doubts.
Thank you, Biagio
Setup:
CEM60, William Optics 120/900 refractor with 0.8x reducer (720mm f/6)
ToupTek 533C camera (3008x3008 / 3.76μm pixels)
Resolution: 1.08" /pixel
ToupTek AAF focuser, NINA software
jpg images from Siril Autostretch (no others adjustment)
you can access images here
https://drive.google...VhA?usp=sharing
#2 rgsalinger
rgsalinger
  • Loc: Carlsbad Ca
Posted 12 March 2025 - 01:18 PM
You're making a mistake in thinking that polar aligning a mount to within 30 seconds is going to correct tracking errors. You need to be guiding with that rig. Polar alignment mostly corrects for DEC drift and not for tracking errors. Check to see if your elongation is in the RA or the DEC axis. My bet is on the RA axis. You can try PEC on the mount if it supports it. That corrects for some tracking errors.
So, I think that the apparent variance is almost certainly caused by environmental issues (wind, altitude, etc) and not by the TPPA. I use TPPA for all of my systems that range from 268 to 2540mm in focal length. Even on my systems a 30 second exposure can show elongated stars. I'm not seeing actual trailing in the images, just some egg shaped stars.
You can't determine anything, though, by photographing a bright star like Hamal for 30 seconds. Pick someplace in the Milky way where you have a large star field. Download a copy of ASTAP and use it to diagnose your issue. I would be shocked if you could get round stars at 30 seconds with that rig consistently.
Finally, consider that when you do TPPA it must be completed within 5 minutes or the numbers will be off. So, if you took longer than that without starting over the number you reached is probably inaccurate. Note also that alignment within a few arc minutes is all that you need to correct DEC drift if you guide the system.
Edited by rgsalinger, 12 March 2025 - 01:19 PM.
  • acrh2 and astro_susa like this
#3 astro_susa
astro_susa
Posted 13 March 2025 - 04:21 PM
Thank you very much for your analysis. I’m still a beginner in astrophotography and I am trying to learn as much as possible. The fact that you advise me to use guiding with this kind of setup is "comforting". Then you mention that even with your equipment you might end up with elongated stars when using exposures around 30 seconds. I’m waiting for the guiding system to arrive so I can try it out.
I would like to understand how to check whether the problem is on the DEC axis rather than the RA axis. I received this advice from other people as well, but I’m not sure how to verify it, I imagine by analyzing the images obtained…
The location from which I imaginig has many limitations. It’s a terrace of a building on a high floor in an urban zone, with a light-polluted sky and a limited view. Besides not being able to see Polaris, I can’t even see the south with the Milky Way. I can only get an unobstructed view from southwest to northwest (or from southeast to northeast from another terrace), and I’m also limited in altitude due to the building’s structure. This is why the other night I ended up in the area of Hamal, not because I wanted to photograph that very bright star, but for the star field around it, other than that I also had a 40% crescent Moon. Next time, I’ll try to find a more suitable star field, given my view.
I already use ASTAP as a plate solver within NINA, but I’m not sure how to use it to diagnose my problem, as you suggested…
I’m having a lot of trouble with NINA’s TPPA because of the two knobs on the CEM60 mount that have to be used simultaneously. Even when moving the knobs slowly and very carefully, always waiting for NINA to analyze the next image, I keep encountering very large error jumps. For example, starting from an instruction like “30″ error, move west,” I immediately end up with “1° error, move east,” making it difficult to achieve an acceptable result. I know that after about 5 minutes the plugin warns you to restart the alignment procedure and I always do. However, the last time I had set in the plugin’s parameters, an error tolerance of 0°, I noticed that the restart message no longer appeared, however I had restarted the procedure several times before finally obtaining that total error of 30″.
If you’re saying that once guiding is implemented it would be sufficient to have a total error of around one minute, that sounds good (if I understood correctly).
If you please could give me some further guidance on how to diagnose whether my problem is related to the DEC axis rather than the RA, and how to verify it with ASTAP, I would be very grateful.
Thanks again for your support,
Ciao, Biagio
#4 rgsalinger
rgsalinger
  • Loc: Carlsbad Ca
Posted 13 March 2025 - 05:45 PM
When you are under the stars, move the mount in DEC while taking an exposure. Or move it in RA, then you will see which axis moves which way. If you post a link to a full resolution image, I'll solve it for you, if you find that difficult, using ASTAP and give you a quick answer.
Astap documentation says this about camera angle versus the mount axes after it solves an image. Basically you should be able to relate the "arrow" shown on the solve to the RA (EW) and DEC(NS) axes.
My AP Mach2 systems can sometimes go 3 minutes unguided with excellent results. Sometimes they can't go 30 seconds. So, I've always just guided. It's easy once you get the hang of it.
One minute PA error is just dandy. I suspect that none of the four systems I'm using now are even that close. Once I get close to that number I stop.
  • astro_susa likes this
#5 astro_susa
astro_susa
Posted 14 March 2025 - 09:21 AM
Thanks again for your helpful suggestions,
as soon as I get a chance I will try to expose moving the DEC and RA axes as you told me, unfortunately the sky will be overcast all next week here in northwest Italy and then I have to go to the hospital for an heart surgery, I hope to get it done sooner !
In the meantime I have uploaded to my drive a .fits file taken on the same evening as the previous files, though pointing toward the Heart Nebula, so the star field should be better than the Hamal one. I also tried solving it with ASTAP and it returned a camera angle of 87.53° then I tried loading the same file into NINA's Frame Assistant which instead gave me an angle of 92.49 and I didn't understand why....
Whenever I mount my camera on the telescope, I always have the doubt on how to position it, being round and without any reference mark on how to place it “straight” respect to the focuser, I never quite know how to do it. I would have expected a reference position on how to start.
In the meantime I received a message that my guide set has been shipped, but it will be about a couple of weeks before I receive it.
The files I uploaded to my drive are:
2025-03-05_20-39-36__-10.40_20.00s_0000.fits     (single light Heart Nebula 20sec)
heart ASTAP.jpg and heart NINA.jpg     (screen shots)
you can access here
https://drive.google...aiw3B98XokLfVhA
Thank you ! Biagio
#6 Spaceman 56
Spaceman 56
  • Loc: New Zealand
Posted 14 March 2025 - 10:18 PM
Biagio.
elongated stars in a 20 second exposure mean that the mount is not polar aligned well enough.
the centre of the mount is rotating in RA around a point in the sky. if this point is not the pole, then we get star trails even in short exposures.
therefore the next objective for you is to better polar align the mount. i don't use NINA, so can not comment on NINA processes.
the CEM-60 is a reasonable quality mount. I think that its surely capable of good polar alignment positioning.
once the mount is correctly aligned the star trails at 20 or 30 or even 60 seconds will go away.
#7 rgsalinger
rgsalinger
  • Loc: Carlsbad Ca
Posted 15 March 2025 - 07:49 PM
Not my experience at all. I can polar align using a range of techniques to under 1 arc minute and while 10 or 20 second exposures are fine, one minute is way too much. If I had elongated stars in a ten second exposure my thought would be optics. In ten seconds you'd have to be degrees off the pole to have even 1 pixel of elongation.
Also tagged with one or more of these keywords: Equipment, Imaging, Mount, Polar Alignment
