Small 1.25" helical focusers for small adjustments
6 replies to this topic
#1 25585
25585
Posted 12 March 2025 - 01:04 PM
Can anyone recommend small 1.25" helical focusers, to make small adjustment for each eye as IF binoculars have?
#2 Andrea Salati
Andrea Salati
  • Loc: Jacksonville, FL
Posted 12 March 2025 - 01:36 PM
If an M42 connection on the telescope side is acceptable, there is a very cheap one available from SvBony and other sources in China.
I used one for a while and it got the job done well enough for me. See picture.
  • 25585 likes this
#3 Enyo
Enyo
Posted 12 March 2025 - 05:46 PM
I have found that just sliding one of the eyepieces up in the holder works very well. Only need to do that when I am using a filter in one eyepiece and none in the other.
#4 balcon3
balcon3
  • Loc: Haifa, Israel. 32.8 N, 35.0 E
Posted 13 March 2025 - 01:41 AM
Be aware that some of the cheaper helical focusers rotate the eyepiece, which can cause distortions. I use a ZWO helical focuser on my Mewlon 180c for micro focusing and it is very smooth. But I put this between the diagonal and the binoviewer, so it is not used for individual eye adjustment.
https://www.teleskop...ng-system-11481
Adding a helical focuser will increase the path length which may affect your ability to reach focus, which is often an issue with binoviewers.
I'm not sure how one would connect a helical focuser after the binoviewer, since there will be just a 1.25 inch eyepiece hole. How will you attach the helical focuser?
#5 Feds27
Feds27
  • Loc: Holmdel, NJ
Posted 14 March 2025 - 04:43 PM
Baader makes one.
#6 denis0007dl
denis0007dl
    Binoviewers Expert
  • Loc: Umag, Croatia, Europe
Posted 18 March 2025 - 01:03 PM
Best one!
#7 arg0s
arg0s
Posted 22 March 2025 - 04:26 PM
A recommendation I've seen for the Heritage line of telescopes is YZ-18839. It's like the Svbony focuser, but the input and output are both 1.25", so no threading required. Never used it myself though.
Edited by arg0s, 22 March 2025 - 04:27 PM.
