Vixen R130S
3 replies to this topic
#1 Alterf
Alterf
Posted 12 March 2025 - 03:30 PM
This came my way on the cheap.  I used to own a nice R150S, and I hoped its little sister was just as well-made.
It is! The weak link on these scopes was the sled focuser.  The gear mechanism is part plastic and just stripped over time.  My R150S's focuser was still workable, but this R130S's was not.  I suspect given the condition of the rest of the telescope that the gear was stripped very early and the telescope sat on a shelf unused.  The rest of the telescope is almost like new.
The solution for me was a Vixen 36.4mm-to-T-thread adapter and a Baader T-thread-to-1.25" adapter and helical focuser. Almost all of my eyepieces are Pentax or Vixen and nearly parfocal.  The Baader unit has about 5mm of movement, more than enough to satisfy all of them if I lock the sled in the right place.  (This solution was suggested by Eddgie in a prior thread here on CN; it is working for me.)
The scope was out of collimation, but only the primary needed adjusting, and a collimation eyepiece was sufficient.
I had it out last night (on my rejuvenated Vixen SP).  Views are all I could ask for from a 130mm Newt.  With a Pentax  20mm XW and 10m XW, the big clusters in Auriga were super sharp.  With a 2.5mm Vixen eyepiece for 288x, Castor was superb---two dots with a dim ring around each, just as expected.  Jupiter was nice, too, with lots of detail, and I could easily tell Europa from Ganymede by size and color, something I did not expect with a 5" scope.
The scope is extremely well-built.  My R150S never lost collimation, and I suspect the R130S will keep it well.  Everything (but the sled gear) is aluminum and stainless steel.  It's no wonder the telescope looks new; it's built to last.
My SP's tripod was designed for a long refractor, so sometimes I had a hard time looking into the eyepiece, which sat at about 175cm.  I think if I use this scope a lot on that mount, I will want to pick up an older Vixen tripod with shorter legs.
Best,
Val
  • osbourne one-nil and Bomber Bob like this
#2 starblue
starblue
  • Loc: St. George, Utah, USA
Posted 12 March 2025 - 04:48 PM
I've never heard of this scope. What were the Vixen models that had sled focusers? The only one I know about is the 5.5" Comet Catcher, made for Celestron by Vixen.
  • Don W likes this
#3 jurdea
jurdea
  • Loc: Centennial, CO
Posted 12 March 2025 - 05:24 PM
The Celestron C6 newtonian which is usually found paired with a Celestron/Vixen Polaris mount.  Basically the same scope.
#4 Alterf
Alterf
Posted 12 March 2025 - 08:29 PM
Vixen also sold an R135S and an R100S f/6 that had sleds.  And yes, the C6 also had one.
Val
