Hi everyone, I recently installed my new (second hand) Losmandy G11 mount (running on Gemini 1v4) on my home observatory. I've been having a very difficult time trying to get it to confidently do automated meridian flips with the legacy sequencer in NINA. After reading up on several forums and groups, I read that in order to configure this correctly, there are several parameters one has to set both in the Gemini 1 and in NINA. The issue I'm facing is that after setting these parameters NINA will actually give the flip command but it'll get stuck in an endless flip command loop, and as soon as it finishes, insted of resuming imaging, it will again run the flip command sequence, although the telescope has already flipped (thankfully it won't flip back risking the tube crashing into the pier, it'll just stay in the flipped position on the east side of the pier, but the imaging won't resume).
To make things worse, there are a couple of things complicating the situation. For one, I'm in the southern hemisphere, so as far as I could read and learn, my settings on my mount have to be reversed (so I should input the east limit on the west limit field and vice versa), which makes trying to follow instructions very confusing. Also, the side of pier reported by the mount as shown by nina is always incorrect, which makes me wonder if that is making the problem worse (it reports EAST when my telescope is on the west side of the pier, and viceversa). I have tried disabling "use side of pier" in the settings in NINA but this hasn´t helped.
My current limits are 95 degrees both east and west, and my "western goto limit" is at 5 degrees. I also tried it at 0 and at 90 but this didn't solve the issue. I have very conservative limits because unfortunately having the RA motor on the right of the mount (facing the pole) this makes my western limit very small (normally a problem reserved for the easter limit for users in the northern hemisphere). I have also tweaked the NINA settings within a reasonable range of values, including the wait for meridian setting, but nothing seems to work and I will get into the infinite meridian flip command loop in NINA.
Like I said, I tried fine tuning all the parameters but nothing seems to work. NINA will send the flip command, wait, re center, wait, and then start over again.
Any help will be greatly appreciated!
