Stellarium Scripting - get ecliptic lat/long of constellation boundaries?
Software
4 replies to this topic
#1 beanfrog
beanfrog
Posted 12 March 2025 - 05:15 PM
Hello,
I'm working on a Stellarium Script to help with something we're doing in class(Astrophysics).
Does anyone know if there's a way to get the ecliptic latitude and longitude of the boundaries of a given constellation?
Pic related, I'm hoping to figure out where the boundaries cross the ecliptic. For reference if necessary, this is to locate where a planet is within a constellation, as I am able to get a planet's ecliptic position.
Looking at the ConstellationMgr docs (https://stellarium.o...llationMgr.html), there are flags to get whether or not the lines are enabled, and to select all constellations (from what I can see, no way to select just one?)
Someone with more experience here, is what I'm asking even possible through the scripting engine?
  • 2025-03-12T15:00:57,076860509-07:00.png
#2 triplemon
triplemon
  • Loc: Portland, OR
Posted 12 March 2025 - 06:02 PM
All scripting API functions in Stellarium are geared towards controlling on-screen display, not querying a database and certainly not doing spherical math computations.
At most you can take the constellation boundary definitions on disk and use it to calculate your own intersections.
Or, likely more involved, write a plugin in c++ to access the datastructures underlying the on-screen displays.
A easier way would be to get constellation boundaries from the web, so ask google
https://www.google.c...undary polygons
The University of Strasbourg is likely the single biggest treasure chest of open source astronomy data and code. Its where stellariums constellation data comes from.
https://cdsarc.cds.u...z-bin/cat/VI/49
If you're into coding - for most problems in life your're likely not the first to have to solve them, so always look at StackExchange first
https://astronomy.st...tial-body-is-in
Edited by triplemon, 12 March 2025 - 06:41 PM.
  • gzotti and beanfrog like this
#3 beanfrog
beanfrog
Posted 12 March 2025 - 10:46 PM
Thanks - the stackexchange discussion led me to a few helpful-looking json files.
I know some basic c++, I'll probably end up trying that. Thanks for pointing me in the right direction, I'm pretty new to Stellarium and astronomy in general.
  • triplemon likes this
#4 gzotti
gzotti
    Stellarium
  • Loc: Vienna, Austria
Posted 13 March 2025 - 05:47 PM
If you retrieve planet data (core.getObjectInfo("Mars") or so), key iauConstellation includes the object's constellation.
#5 beanfrog
beanfrog
Posted 18 March 2025 - 11:36 PM
Hello all - just wanted to give an update
I was able to get some rough Ra/Dec values from https://www.cantab.n...ery/zodiac.html which required a little bit of manual tweaking.
They're definitely not astrophotography levels of accurate, but as I'm just approximating some distances they're perfectly fine.
as triplemon noted, Stellarium scripting is definitely not the best for spherical computations, but I ended up making a couple of simple calculations work to a reasonable degree of accuracy.
All I really needed was the angular separation in radians, which isn't difficult:
where (α11) and (α22) are points (ra, dec)
cosΘ = sin(δ1)sin(δ2) + cos(δ1)cos(δ2)cos(α2 - α1)
Θ = arccos(cos(Θ))
As I believe I mentioned, the object of this script is to approximate an objects position within constellation boundaries, which I'm doing using an array where the closest index is replaced with a dot to represent the object.
I've attached a photo of what that ends up looking like.
I'm posting this to share what I learned and if someone has similar needs, whether in high school astrophysics like myself, or anything else.
You can find the script on my GitHub at https://github.com/b...sp-tracking.ssc
(edit: add image)
  • 2025-03-19T07:49:17,178359668-07:00.png
Edited by beanfrog, 19 March 2025 - 09:52 AM.
Also tagged with one or more of these keywords: Software
