Well, Bruce or BRGE and I started this conversation in PM's last 15 June 2024 and today I am going
to start this thread to both help Me and anyone else interested in what it takes to build and test
one of these interferometers.
Not sure one would say it is Inexpensive...well not millions of dollars, but likely well beyond what most
of use would be willing to spend on something unless really necessary.
Sadly, a BATH interferometer cannot test Fast Concave and Convex surfaces and that is required for
the 2 Corrector lensed in our 18 inch F12 CDK that Mike Jones designed for us.
Since One Off Optical Lenses are quite Expensive, like greater than US$5k each we decided to make these
2 lenses at 90mm diameter ourselves.
I will give the Lens Radiuses shortly, but first one will need these Abbreviation's to even have a chance of following
this conversation:
Thus, the following list to star which may be added to as we go along our way :
AI Adjustable Iris
ASM Autostigmatic Microscope
BE Beam Expander with reference behind the BE as to the power ie 2X or 5X ect
CAM1 Camera 120FPS Global Shutter USB Camera
CAM2 Camera Lucid Triton 5.0 MP Model (IMX264)
CCTP Corner Cube Trihedral Prism
CPF Circular Polarizing Filter
FM Folding Mirror
FR Fresnel Rhomb (Multi-Wavelength 1/2 waveplate Fresnel Rhomb Polarizer Rotator UV/VIS/IR
HWR Half wave retarder alternate name for HWP
HSPMI High Stability Plane Mirror Interferometer i.e. the Zygo 7006A
MgF2 MgF2 Window
MO Microscope Objective
MUT Mirror undertest is in the test arm at a distance equal to its RoC from the point where the MO brings the test beam to a focus.
MWPR Multi Wavelength Polarizer Rotator
NDF Neutral Density Filter
NPBS Non Polarized Beam Splitter
OPD Optical Path Difference
OPL Optical Path Length
PBS Polarized Beam Splitter
PSI Phase Shift Interferometer
PH Pin Hole
QWP Quarter Wave Plate
QWR Quater Wave Retarder alternate more descriptive name for a QWP
SNB Silicon Nitride Ceramic Ball
TG Tywman Green Zygo 7006
TG LUPI TG interferometer with unequal path length for test and reference beams (requires long coherence length monochromatic light source)
With Bruce's Very Kind help in telling us what we need to purchase, we hope that we have purchased everything
needed for the construction and can now move forward.
We have machined various holders for Lenses, Filters, ect and will likely be machining more parts required as we go.
We have also 3D Printed various parts and stands to test thing and concepts that may need to be machined in aluminum
or SS as we go along
Hopefully, this will be interesting and beneficial so some of you.
Very Best Regards,
Preston
Edited by PrestonE, 14 March 2025 - 03:44 PM.
