A few weeks ago, I was very, very fortunate to take delivery of a new TEC 160fl numbered 147. Unfortunately, atmospheric conditions have not allowed for a decent evaluation of optics, and I've not yet had the opportunity to DPAC test. That said, I do have a few early observations:
- The TEC's weight to aperture ratio is remarkable. The scope weighs 33.7lbs fully dressed with a 19" Losmandy plate, rings, captains ring, 7x50 finder, and baader bbhs diagonal. Consider that my comparably equipped TOA 130 weighs 32.6lbs. If, like I was, you are on the fence about whether a 6" refractor is more than you want to handle, the TEC is a great option if you do decide to take the plunge.
- Unfortunately, my Panther TTS 160 mount/Planet tripod is not up to the task. Settle times are around 3 seconds - which i could live with - but there is too much shaking when focusing. Once focused, stability is adequate. And tracking is good. I suspected the Panther might struggle with the TEC and so, as a contingency, ordered a Panther Lite about a month ago that should be here this summer. Until then, I'll continue playing around with the TTS 160 to see if i can achieve any improvement.
- Again, there has simply been too much turbulence to permit a decent evaluation of optics, but I'll risk a few early impressions:
- No discernible coma. For me, this is BIG. Any hint of coma and/or astigmatism ruins the esthetic that I so value in a refractor. For me, coma ruins the view when observing doubles, carbon stars, etc.
- No discernible astigmatism when racking inside/outside focus at high power. Again, this is BIG for the same reasons I note above.
- I am seeing some inner zone at sufficient defocus. Need a better night to assess.
- Spherical error @ 525nm appears to be very well controlled, although turbulence has made it impossible to assess with certainty. And I'm not seeing any indication of a turned edge - which I find is all too common even with premium refractors. Looking forward to DPAC confirmation.
- I did see some blue/purple fringing on the limb of the moon - but the moon was at 35 degrees at time of observation.
- I had a fairly solid view of Jupiter the night I received the scope. I did not have another scope setup for comparison, but I was satisfied with what I saw given Jupiter was around 35 arc seconds and seeing was no better than 3/5.
I'll share an optical update when I have a sufficient fact base (probably be a few weeks). Overall, I'm feeling optimistic that i am going to be quite pleased with this scope.
Edited by scoale, 13 March 2025 - 04:32 PM.
