De-extension adapter for eyepiece
#1
Posted 13 March 2025 - 05:22 PM
Thanks again in advance
#2
Posted 13 March 2025 - 05:39 PM
I have an extra adapter for 2" to 1.25" that allows a little more in-focus.
#3
Edited by rgk901, 13 March 2025 - 05:40 PM.
#4
Posted 13 March 2025 - 08:08 PM
Ultimately this is life with a reflector. Reflector has short focus travel. It’s in the design. So these are the things you have to do to make everything reach focus.
You could always attach 2”-1.25” adapters to each of your Morpheus.
You could also try to get fancy and measure how much focus travel you need. Perhaps moving the mirror a couple mm will do it, or perhaps a shorter extension.
- eblanken likes this
#5
Posted 13 March 2025 - 08:43 PM
Edited by SparkyMike2010, 13 March 2025 - 08:45 PM.
#6
Posted 13 March 2025 - 10:38 PM
Uhm, no, sorry, that won’t work. You could use a 32mm Plossl which is 1.25” instead of the 30mm but the view won’t be as wide.I guess I can attach a 2 to 1.25 adapter on the 30mm and use the Morpheus at 1.25.
#7
Posted 14 March 2025 - 10:18 AM
#8
Posted 14 March 2025 - 11:23 AM
There is such a thing, but it doesn’t work with 2” eyepieces.Yeah I’m in guessing I’ll be stuck removing the extension when going back to the 30mm. But I was hoping somebody would know of an adapter I could put and leave on it to avoid adding and removing adapters.
#9
Posted 14 March 2025 - 05:52 PM
The adapter always stays on one of the morphs so removing it is same as removing a 2" eyepiece, it slides out together... and when it's in, the morphs are replaced same as any 2" eyepiece just from the adapter screw vs the main focuser screw... unless I am missing something here I don't understand the issue?Yeah I’m in guessing I’ll be stuck removing the extension when going back to the 30mm. But I was hoping somebody would know of an adapter I could put and leave on it to avoid adding and removing adapters.
Edited by rgk901, 14 March 2025 - 05:55 PM.
#10
Posted 14 March 2025 - 06:53 PM
#11
Posted 14 March 2025 - 08:06 PM
What rgk is saying is that you can put 2”-1.25” adapters on your Morpheus eyepieces, which will allow you to reach focus with them without using the extension. This would eliminate swapping the extension in and out. It just means buying a few adapters.The morphs all come as 2” eyepieces. The 1.25 to 2” is already installed. When using the morphs I need to use a focuser extension to get them to focus. With my 30mm Apertura I can not use the extension bc it won’t come into focus. I was hoping to have an adapter attach to the 30mm full time so I wouldn’t have to swap the focuser adapter basically
#12
Posted 14 March 2025 - 08:57 PM
I just don’t like messing with adapters in the dark and was trying to find out if there’s an adapter I could leave on the 30mm to save the step of adding or removing the extension tube.
I only use the 30 mm a as a finder, then add the extension and onto the morphs from there.
Edited by SparkyMike2010, 14 March 2025 - 09:00 PM.
#13
Posted 14 March 2025 - 10:33 PM
Yes, we understand that Morpheus has a built in 2”-1.25” adapter. Don’t try to remove it. But if you use the 2” barrel, you need to use an extension to reach focus. If you put a 2”-1.25” adapter in the focuser, and then put the Morpheus 1.25” barrel in that, you won’t need the extension. We understand this is completely unnecessary. But it gets rid of the extension, which seems to be your objective.The morph come as both a 2 with a 1.25 built in… I think. I’ve never tried separating them to be sure. But that doesn’t save me anything because the 30mm is 2” so after locating my target with the 2” I’d have put the 2 -1.25 adapter for the now stripped down morph! 😆😆😆 Part of the reason I bought the morphs was because they are all 2”! Oh the irony!
I have the other situation. My 24mm 82 requires an extension to reach focus in my reflectors. So I like using the built in 2” barrels (instead of using a 2”-1.25” adapter) because I can just leave the extension in.
There is such a thing as an in focus adapter, but it can only take eyepieces up to 1.8” wide, because it has to fit inside a 2” focuser. So it won’t work with the 30mm.
Edited by SeattleScott, 14 March 2025 - 10:54 PM.
#15
Posted 15 March 2025 - 12:29 PM
- rgk901 likes this
#16
Posted 15 March 2025 - 03:27 PM
Uh, why not use the Morpheus as 1.25" eyepieces? That is what they are, 1.25" eyepieces.
The 2" machined outer barrel was merely for convenience in some settings.
But all your eyepieces will be closer to the same focus if you use the 30mm as a 2" and the Morpheus EPs as 1.25".
No extension required for either. Problem solved.
I believe your scope came with a 2" to 1.25" adapter? Just keep it in your pocket when using the 30mm, and put it back in the focuser for the other eyepieces.
Edited by Starman1, 15 March 2025 - 03:30 PM.
