So Whereisclearsky, there's a problem somewhere in this rig. I thought you had posted a photo of it but I can't' find it - if you did you could just post the link here. Same with the guide log.
The rig is AM5 + 2600MC + RedCat 61 WIFD + ZWO 32 mm guide scope and 120MM (mini?) guide camera + ASIAIR. Something isn't working leading to field rotation.
The issue could be poor polar alignment; there was an ASIAIR bug in approx October 2024 that made polar alignment wrong and consequently star were oblong.
Here are the things I'd like to ask about:
- what ASIAIR version is being used? Update to the latest if possible.
- what ASIAIR polar align version is being used? There's an original polar alignment function and a new one. The new one does not need to see the pole. However, switching to the original one would be a good diagnostic step.
- Check polar alignment by starting with mount in home position, polar aligning, going to a target, sending mount to home position again and verifying that the polar alignment did not become significantly different.
- Clear the guiding calibration every session (for now). Guiding can go crazy if you don't do this.
- verify everything is correctly assembled and nothing is wobbly - tripod spreader, telescope attachment to dovetail, guide scope attachment to handlebar
- check guide camera focus.
- check ASIAIR config - location, focal length of RedCat and guide scope
I'm certain that something simple and obvious is wrong; if so rest assured we have all been there. Best wishes.
