I'm prepping to do my 2nd Messier Marathon attempt in a few weeks and in my constant quest to overthink everything, I've been poring over various published MM sequences. I'm not finding discussion comparing the sequences, so I wanted to present a summary here and invite any insights or thoughts.
While the published sequences are available, one thing that tends to be lacking is the context of why the author chose this particular sequence. I'd love any input on why one might work better than another. For instance, there's a "more daring" sequence that tries to knock out some super easy ones in the early evening before going for "the Setters." Some others might be better for certain latitudes. (I'm at 36N latitude.)
The two sequences from books are the Machholz sequence (from The Observing Guide to the Messier Marathon) and the Pennington sequence (from The Year Round Messier Marathon.)
Others are from other places online. In particular, the well known SEDS site lists some sequences here. And Larry McNish's Messier Marathon Planner on the Royal Astronomical Society of Canada website lets you input date/location info, and then choose from seven different sequences.
First-- here are some CN threads:
- Tips for doing a Messier Marathon - general tips but doesn't really discuss sequences.
- Messier Objects Marathon Tracker - in which CN user Jay_Aky provides a spreadsheet that can be used for Marathoning.
- The thread simply called Messier Marathon discusses apps that have sequences; and CN user gfamily provides a spreadsheet that contains the Machholz sequence. I have taken this spreadsheet and added some of the other sequences to it that you can sort by-- feel free to make a copy here. (With a nod and thanks to gfamily).
So with that-- here's a summary of the sequences I can find. Most of them have very similar starting and ending sequences, and some similar subsets, but there are definitely differences.
- Machholz sequence (multiple sources including SEDS page and McNish planner). The original.
- Pennington sequence (from McNish planner). Seems to generally be similar to Machholz, but pushes some of the winter objects later.
- Phil Harrington sequence, Astronomy magazine 1994, then presumably 2002 (from SEDS page and McNish planner). Deviates from Machholz/Pennington in that it pushes some of the bright winter ones earlier in the sequence before the "setters". It also has somewhat of a different sequence for the spring objects, pushes Draco and Coma Berenices objects much later, and pushes Summer Triangle objects much later. (I'd love to hear theory on why.)
- Ed Ting sequence, S&T March 2000 (from McNish planner). Follows Machholz very closely with the exception of pushing Hydra objects earier.
- Tomm Lorenzin sequence, 1997 (from McNish planner). Puts southern winter objects ahead of more northern ones; pushes circumpolar objects later; pushes Coma/Virgo/spring objects earlier.
- Astronomy magazine, March 2006 (from McNish planner). Appears to be identical to the Machholz sequence.
- Larry McNish for latitude 51N (from McNish planner). I haven't looked at this sequence but it seems pretty obvious it's optimized for northern latitudes.
- Tom Cameron for Calgary RASC (from McNish planner). I haven't looked at this sequence either, but I'm guessing it too is optimized for northern latitudes.
- Dawn Jenkins sequence (referenced on SEDS page and taken from her own page, http://www.astras-stargate.com/messlist.htm). Very specifically moves some (circumpolar) Cassiopeia objects to very late in the list, and reshuffles some of the winter objects. The rest of the list is similar to Machholz.
- Bill Farris sequence, 2002 (from http://www.messier.seds.org/xtra/marathon/mm_bfe.txt) This is an interesting one, in that he says it is "unconventional and risky" because he specifically pushes some bright winter objects to the very front of the sequence, before the setters. His sequence also is divided into groups, which may help conceptualize it.
- Stephen Saber sequence (from https://saberdoesthestars.wordpress.com/tag/stargazing/) This one is also interesting in that his goal here is to be able to do it all from memory. To that end, his sequence is fairly standard but he divides them into 10 groups with mnemonic names. This type of "divide and conquer" may be helpful even for people not trying to do it from memory.
- Marathon sequence for latitude 18.5 (from http://www.messier.seds.org/xtra/marathon/marat-in.txt). I haven't looked at this sequence, but it specifically states that it's optimized for a more southerly latitude.
And again, I would really love any thoughts as to why someone might prefer one over the other! Going through these, comparing them, and compiling this list gave me some insight, but I'm sure I'm missing something.
