I have a C14 XLT that I upgraded (changed the tube to a carbon fiber tube and installed mirror locks). I also added the Starizona Large Format focal reducer/field flattener. I'm pretty happy with the pictures I take with it, although it's a lot of work making sure I have good collimation, little to no tilt, great focus, and other things like making sure the corrector plate is correctly centered.
I recently bought a new CDK12.5; what an amazing scope that is. No corrector plate, the Hedrick focuser and Dew controller are amazing, it holds collimation like forever, the ease of use is a welcome pleasure. There is no comparison to the quality and ease of use.
Because both scopes (the C14 with the reducer) have similar fields of view (2665 for the C14 and 2541 for the CDK) and speeds (7.5 vs. 8), I'm going to sell one. I originally bought the CDK to replace the C14. However, once you have the C14 really well collimated, focused, and with little or no tilt, then due to its larger aperture, it collects 25% more photons than the CDK. My subs have more detail. For me, at the end of the day (night actually), what matters most is the data on the subs, not how easy it was to get it.
The mount I use is an AP900 the, camera is AASI2600mm pro, I use ZWO large OAG, Wanderer rotator, tilt adapter, ZWO 7 position filter wheel. One other difference is that the train on the CDK is 68mm in diameter up to the camera which is 54mm. The wider train gives my OAG a lot of room, and I believe helps minimize flexure on the train.
I can't afford a CDK 14, but any input on which scope to keep would be greatly appreciated.
One last thought, will using 25% longer subs compensate for the 25% greater aperture? I have had really cloudy nights (pun intended) lately and have not tested that.
Phil
Edited by philsan300, 15 March 2025 - 11:49 AM.
