Thought I would post this for those with one of the old Synta EQ1 mounts or equivalents (such as Orion, Celestron, Meade etc. rated at ~7 lbs. load capacity) that may want to improve the mounting and usage capabilities. I have one of the last Orion versions of the Synta with extruded aluminum legs, and marketed as updated, large triangular accessory tray for added stability and some other minor stuff. Originally for my ST80. Some of these suggestions will apply to the newer versions also.
The EQ1 is much maligned in the forums for various reasons. Many overload the mount which causes most of the problems. If the ota is lightweight the mount can easily handle the scope. ST80 or 114mm fast newt is about the max weight. Lighter is even better. A 3-4 lb or so refractor as discussed in the...
Unusually Inexpensive Refractor thread...
https://www.cloudyni...3#entry13485942
Maybe 60mm or 70mm or less, keep it lightweight whatever your aperture and price range.
My Orion EQ1 is now home for my Kenko/Borg (Japan) Moebius 55, 55/600 ota, weight is 1kg, 2.2 lb. A nice little Japanese optics refractor and not inexpensive.
Any lightweight ota needs a easy to use lightweight mount. The EQ1 can fit that requirement with a few simple modifications.
A large triangular tray or piece of plywood or plastic on the tripod spreader. Adds stability to the tripod.
Knobbed M6 machine bolts to replace the hard to find in the dark RA/DEC axes lock bolts. They come with a choice of knobs and lengths.
https://www.amazon.c...062914899&psc=1
Add a second setting circle pointer to your DEC axis opposite the existing one. Easier to set the degree coordinate on your DEC setting circle. I cut a thin width of self adhesive white metal tape . Use colored tape, or another metal pointer, whatever you can find. Lock the DEC axis, use the slomo to set the pointer (such as 90 degrees), put your pointer directly opposite.
Edited by dmgriff, 15 March 2025 - 06:21 PM.
