Although Clear Dark Skies had seeing at 2 of 5, I needed to continue collimation and star tests after a week of clouds and several rain storms. The conditions were too poor for me to try fine adjustments using the focuser tilt ring, but secondary mirror adjustments were very close. Using Hasselah in Auriga, here are the at-focus airy disc, intra-focus and extra-focus test images.
And I captured Jupiter and Mars with 685nm IR Pass filter. Trying to get R-G-B filter data was futile for the seeing conditions. For Jupiter, the camera was set at 10ms, running video at 100fps, for 1 minute, stacked a third of the frames in AS4, and used the FFT denoise routine in WS, which is new for me.
For Mars, same filter except I wanted to confirm I could use a shorter shutter speed and faster frame rate without dropped frames. Camera was set at 4.8ms, running video at 205fps for 1 minute, AND no dropped frames. Similar processing as with Jupiter, adding de-rind.
I know it's late with Jupiter getting lower in the sky and Mars getting smaller. But this is good preparation for later. And this telescope still needs a little more adjustment. Thanks for looking
Paul
