Hi!
Can I observe the sun with my 40 mm Lunt after a deleted ealon filter on the front of the telescope?
Is it safe?
Can I take pictures this way?
I would like to take a picture in white light, that's why I have such an idea.
Paul
Posted 16 March 2025 - 10:30 AM
Hi!
Is it safe?
Paul
Posted 16 March 2025 - 10:44 AM
Posted 16 March 2025 - 11:20 AM
Hi!
Is it safe?
Paul
NO!!! That Ealon and Diagonal filters OUT the DANGEROUS LIGHT that will damage camera sensors and EYESITE! I think you want to multi purpose the Lunt 40 scope and use a White Light filter Solar Filter? I would get a SVBONY SV503, $330 and then get that Solar Filter..
So the Lunt is ONLY a Solar Telescope when used correctly. SAFTEY IS MOST IMPORTANT.
Christopher
Posted 16 March 2025 - 12:31 PM
As Gary states you can just tune the etalon off-band for a (red visually) continuum image, and requires no additional expenditure.
Removing the etalon and blocking filter will allow use with a Baader AstroSolar film objective filter (and a normal star diagonal for the eyepiece or camera). A Baader Continumm filter can be added to the diagonal or eyepiece for a bit more clarity if chromatic aberration or atmospheric dispersion needs to be dealt with.
I personally think a 1.25 inch Herschel wedge would be overkill for use with the "naked" LS40 OTA, unless you want to later use it with a larger instrument.
![]() Cloudy Nights LLC Cloudy Nights Sponsor: Astronomics |
