I am very interested in increasing the focal ratio of my AT130 EDX by stopping down the aperture using an aperture mask. There are many informative threads on CN about their benefits. I have never had one or used one, so I have questions about making one or more for my scope.
First, I did a search online and found focusing masks and off axis masks, but none made for refractors. I admit that I have been observing for decades and never tried one because I didn't know about them or think about them. Now I wonder if an aperture mask is superior to a Barlow lens for increasing the focal ratio. They have zero glass, less weight, less expensive, and should work fine with my binoviewer. Why aren't these things more popular?
Incidentally, my 4.5" reflector from 1970 came with a cover and a central 2" lens cap for viewing the sun. The scope also came with a solar filter that threaded onto the .965 barrels. It's scary to think that I used that filter a few times to look at sunspots.
My plan is to make a 5" objective cover like the one that came with the scope and cut a 4" diameter hole in the center. On top of this, I would add a second cover with a 3" opening. And maybe add a third cover with a 2" opening. I would like to try all of these- it will be like swapping scopes without the effort.
So, how do I make this thing? Metal is good and would have a sharp edge but is difficult for me to work. Wood is easy to work with but doesn't have a sharp edge. That leaves plastic. I would want this to be light weight and easy to use. I would also want to be sure that it doesn't mar the finish of my new scope. And I definitely want to keep this away from my precious objective lens so it will have to mount over the dew shield. I have a wood shop and woodworking skills, but no 3D printer. I plan on making some paper masks sometime soon and experiment with them before making the final product.
Does the mask perform better when it is close to the objective, or doesn't that matter? What material do you think is best? Should I consider making different masks with different openings rather than this all-in-one idea of mine? Should I use felt to hold it in place like the original objective cover or something else? How important is the sharp edge of the opening? I will probably cut 1/16" plastic sheet using a jig saw, so the edge will not be too sharp.
I would be very interested in seeing any homemade masks and learning from your experience.
TY, Rob
Edited by robjme, 16 March 2025 - 11:50 AM.
