Thank you, JRF, for your thoughts on minimizing scatter by minimizing air-glass interfaces within eyepieces. But such a tradeoff would mean giving up a wide AFOV for something like 50 deg or less, a trade I am not willing to make, except perhaps at the highest power for planets.
Thank you too, "Seattle Scott", for the link to the "Ernest's" (the Russian). evaluation of eyepieces. I believe he has done a diligent job in evaluating a large but still incomplete variety of eyepieces. With criteria of 68 deg AFOV or larger and, at f/10; center, half-field, and edge-of-field spot size no greater than 5 arcmin, I identified over twenty eyepieces. Some of these are no longer made and others are rather rare.
However, one obvious trend stands out: it appears in general that the spot sizes generally increase with larger eyepiece focal lengths. There are many choices at or below, say 12mm but few at larger wavelengths. Now an edge-of-field spot size of 5 arcmin is a stringent requirement, and perhaps that might be relaxed for longer wavelengths?
Another thing that stands out: a very few eyepiece lines pretty much meet (or at least come very close) to meeting my spot size criterion at focal lengths at or below 12mm, and then there are just a few good outliers thrown in. Among the eyepieces that meet my criteria are:
--Televue: Delos, Ethos, and the T6 lines; also the Nagler 9mm T1,
--Baader: Morpheus 4.5mm, 6.5mm,
--Meade: PWA 5000 4mm & 7mm and UWA5000 5mm & 8.8mm, and
--Nikon NAV 7mm.
The only William Optics in the bunch was the UWAN 4mm, same as the AT XWA clone, I believe.
Among the eyepieces of longer focal length than 12mm, only the following met the criteria:
--Celestron Axiom 19mm and
--Televue Nagler T5 31mm.
Ernest also listed specific aberrations in most cases. In general but not always, smaller spot size was correlated with less aberration.
Specifically, two eyepieces did not meet my two criteria, although they scored quite well. These include the ES 82 deg AFOV 30mm, which I own, and the much-boosted ES 92 deg AFOV 17mm. Nor did any of the Pentax XW line make the cut, although several were close.
I had hoped that narrowing the telescope light cone from a Dob-like f/5 to a more forgiving f/10 would reveal a good number of eyepieces that performed to near-perfection, even some of the less-expensive ones. This latter was clearly not the case. Guess I'll stick with what I have: Ethos 4.7mm, 6mm, and 10mm; Nagler T2 20mm (not tested but very sharp indeed), and ES 82 deg AFOV 30mm. I do sometimes use others' telescopes, and they will do well there too, of course. Oh well.
Happy observing always,
Don
