Masuyama wide fields (85 degree). f/10 will be good.
The optical and build quality is exquisite and they're much lighter than the big hand-grenade eyepieces. I think someone reported it was near perfect at f/12....f/10 will be good. You won't need all that extra glass at f/10.
Unfortunately the view through a 32mm Masuyama 85 was blurry looking halfway through it's wide field in my F/10 C11. Having said that, it provided one of the best views ever on many nebulae and is a pleasure to hold, kind of feels like a 22mm Nagler T4 in build and size.
One of the best center fields I've ever seen in an eyepiece followed by one of the worst outer fields. I still wouldn't mind owning one again though. The center is that good. It should work better at F/12 like Scott99 said.
100 degree eyepieces work great with regular and edgehd SCT's. Hard to go back to sub 70-80º when you try one that actually fits your face lol. I've been hooked on hyperwide fields of 90º+ ever since I found the right ones for my eyes/cheeks.
It's good to have some sharp Orthos, etc or Delos/Pentax for planetary viewing (or other uses), but for deep space views, especially large open clusters, nothing matches the big field eyepieces I find, especially in a larger SCT where you inherit small views off the bat. I get a very sharp, clear and almost a full degree with a 25mm 100, .7 with a 20mm 100 and .62 with a 17mm 100. More if I add the focal reducer. Also, an eyepiece that weights 1-2lbs is usually not a big deal for an SCT.
Just my 2 cents, clear skies!
Edited by Procyon, 19 March 2025 - 03:34 PM.
