I have a 1987 pre-EDT-glass Astro-Physics 6-inch f/8 triplet, quite likely almost the same model as yours. I suspect you will be well pleased with your purchase -- mine is an excellent instrument for visual observing (I am not an imager and never have been). F/8 is slow enough that you may (if you wish) use simple eyepieces with few air/glass interfaces for high-magnification views of low-contrast objects, like fine planetary detail or Sirius B. F/8 is fast enough that a two-inch barrel eyepiece with a field lens that fills the barrel will get a nice wide field of view.
One problem I found with mine is that it is nose-heavy -- that triplet is thick and weighs quite a lot. In consequence, the OTA balances near the upper end of the tube, so the height of the eyepiece varies through a considerable range as you change from viewing objects near the zenith to ones near the horizon. If you are primarily into imaging, this may not be a problem, and your imaging equipment may weigh enough to move the OTA center of gravity at least a little bit nearer the center of the tube. If not, one useful accessory is a heavy weight attached to a tube ring, which is in turn fastened around the OTA as close to the focuser end as you can get it. I have a small-loaf bread pan cast full of lead in such a setup, and it makes a great deal of difference in using the telescope. (Note to all: Be cautious about working with lead, it is a cumulative poison and a neurotoxin, and we amateur astronomers are weird enough already.)
A second finder is also useful in visual observing with a large, cumbersome instrument.
Clear sky ...
